Home > Td5 > Front door seals (lower)
Page 2 of 4 <1234>
excossack
Thats why I am replacing the seals. I had to replace to door bottoms. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #478540 2nd Dec 2015 10:55pm
miker
Easy job to do? I assume you bought repair channels and then welded them in?
Post #478598 3rd Dec 2015 1:28am
ericvv
dorsetsmith wrote:
your missing these
Thanks for that part number, as so many I will be missing some of these too...
But, those little simple small foam blocks from various resellers cost from 7 to 9£ each. Shocked
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #478604 3rd Dec 2015 6:29am
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
Fitting the new type seals to a Td5 is easy, I've fitted them to mine and they give a much better seal. Remove the door card, drill out the rivets, enlarge the rivet holes my 1mm, drill a couple of extra holes for the side bits, Hoover the rivets etc from inside the door, clip new ones into place.
Post #478606 3rd Dec 2015 6:52am
excossack
Yeah not a bad job to replaced the bottom sections. I got one per door and then painted each one up before hand.
Between the frame and door skin, I used roofing sealant to create a gasket.
When all done and painted I used cavity wax in the box section.
Given I need 4 of those foam pads for the front doors, I might as well just replace the newly fitted door seals with Puma ones and do away with the need for £18 of pads per door!
And this time, I will try not to put a snapped drill bit into my finger, under the skin and out the other side! 1999 Defender TD5 110
Regards
John M0VAZ
Post #478618 3rd Dec 2015 9:10am
Romadog
So the new Puma seals don't fit early welded frame doors??
Post #478840 3rd Dec 2015 8:10pm
dorsetsmith
ericvv wrote:
dorsetsmith wrote:
your missing these
Eric
not in lest you driver TD5 Mr. Green
Post #478858 3rd Dec 2015 8:59pm
ericvv
^^ I think those little Td5 foam blocks are probably still the same ones as installed on early Puma bottom door seals, including on my model year 2009.
If someone knows better and maybe have a different part number for these foam blocks on a pre-2012 Puma (2012 is the model year that the new type door seals were introduced), I would be interested to hear that.
Post #478865 3rd Dec 2015 9:24pm
dorsetsmith
OK
Post #478867 3rd Dec 2015 9:27pm
excossack
Looking at the link to the blog posted earlier, looks like the door changed shape. They went from almost a 90 degree joint for the bottom frame and side frame to a more curved frame (at least on the front doors) 1999 Defender TD5 110
Regards
John M0VAZ
Post #478901 3rd Dec 2015 10:41pm
driver9
Foam block 85p from a LR dealer and free delivery.
http://www.shop4landrover.co.uk/product/FOAM_BLOCK_AWR3140
Post #478962 4th Dec 2015 8:13am
roel
Yes it looks like it went from a welded together frame to a pressed frame. Should be less prone to rust. Roel
2003 90 Td5 (2009-now)
Post #478963 4th Dec 2015 8:17am
excossack
Looks like I am going to have some fun putting a curve into the door frame. 1999 Defender TD5 110
Regards
John M0VAZ
Post #478971 4th Dec 2015 9:18am
ericvv
Thanks for the great tip. The link worked even better than expected. I ordered 16 of these blocks, need 3 now to replace those that have disappeared over the years, and the rest goes into storage. They may be for a Td5, but they are identical to the little blocks used for the earlier Puma doorstrips which were used until model year 2011. They are the original Land Rover items as in the picture posted by dorsetsmith, and the price was 0.71£ a piece net of VAT. The best thing was that Beadles Land Rover Sidcup, Kent offered free DHL shipping to Switzerland, so I paid a total of £11.36 for these 16 little bags/blocks delivered to our house. No Swiss import VAT either as well below the threshold for that. Whistle
Kudos to Beadles. Thumbs Up Thumbs Up
I should have enough of them now for the coming 20 years or so, ...I hope. Laughing Thumbs Up
Post #481039 10th Dec 2015 5:00pm
driver9
Eric
Pleased you found the link I posted useful. I have used Beadles a few times for parts and each time the order has been dispatched very quickly.
Post #481103 10th Dec 2015 8:23pm
Page 2 of 4 <1234>
