![]() | Home > Td5 > Diesel leak |
cable ties ?
In terms of replacement,how far back does it go? is it an under the car job all the way the the Back ![]() if you measure the pipe on the fuel cooler you can replace damage fitting try this http://www.ebay.co.uk/itm/111658203599?_tr...EBIDX%3AIT |
alexatnd Member Since: 19 May 2015 Location: Yorkshire Posts: 292 ![]() ![]() |
Thanks dorsetsmith
Yup cable ties were my 1st thought and its worked..... Even better, fixed it in daylight without it sipping it down. Yup found out that it goes all the way back, part number WJP500090 £167 +vat for land rover part. I'll check out the link you sent ..... o.k. they look good. be better than cost of full fuel line .... time to measure the pipe I guess Thx Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - new chassis etc back on road Effie - 2004 110 TD5 County |
