Home > Maintenance & Modifications > Cubby removal - Nothing is simple with a LR!
RRUK
In between work calls I thought I'd whip out the old cubby box as I start to prep for the interior changes. It's 4 torx screws, how hard can it be I chuckled to myself - no need to put on garage clothes or get many tools out, just a T30 bit.
Pulled out the cup holder and the front two screws whizzed out in seconds. Popped the caps off the rear two inside and started undoing them, then the inevitable and maddening spinning rivnut scenario on both of them. Evil or Very Mad
So now this will have to be a weekend job when I have a helper who can undo it while I'm underneath with mole grips holding onto the spinning offenders. If the damned car had been built properly this wouldn't be a problem!
This is the type of thing that bugs me about Land Rovers, it should be a simple 5 minute task, but now it will be a lot longer, just because. AARRGHH!!
One job creates 5 more...
Rant over. Big Cry 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #478345 2nd Dec 2015 3:12pm
K9F
If it makes you feel any better...'You are not alone!' From your rear view mirror experiences it should have been expected. Whistle
http://www.defender2.net/forum/topic25927....t+spinning If you go through life with your head in the sand....all people will see is an ar5e!!
Post #478349 2nd Dec 2015 3:31pm
RRUK
Regarding getting mole grips on the Rivnut, is there much space to get at it from underneath?
I have the necessary rivnut tool to tighten it once the old one is out.
Does the TDCi still have the removable floor plate under the cubby area or is that TD5 only? 2016 D4 HSE
Post #478395 2nd Dec 2015 5:58pm
Panda
England 2015 Defender 110 Puma 2.2 XS CSW Fuji White
It has a removable floor plate under the cubby
It would be difficult to get a purchase on the spiny bits, it can be done from the inside by applying slight angled pressure as you undo them. I wish you luck, hope its turns out to be a quick job
Good Luck
Paul Thumbs Up Monty-2015 2.2 110 XS Puma Station Wagon
Yoda Disco 3-Sold
Larry Disco 1-Sold
Muddly XS 90 TDCI-Sold
Pearl Disco 2-Sold
Larry Disco 1-didn't want too but sold
Post #478414 2nd Dec 2015 6:17pm
K9F
Yes, exactly as my post states. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #478669 3rd Dec 2015 11:30am
Barney12
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
Oh how I feel your pain. The exact same thing happened to me and with the rear view mirror too!
Have you tried:
1. Doing it back up tight and then undoing? This can sometimes just be enough to nip the nut up.
2. Exerting sideways pressure on the head whilst unscrewing? I found this is most easily done with a powerdrive with a long extension piece (so you have some space). Get it spinning and then push against the head with a blunt object.
Both the above worked for me on the cubby. Once out I then drilled out and replaced the nuts.
Post #478675 3rd Dec 2015 12:04pm
johnszs
United Kingdom 2004 Defender 90 Td5 XS CSW Alveston Red
I had this too i used molegrips on the spinning rivnuts, when i drilled them out i fitted flanged ribbed ones so hopefully i wont have this issue again 2004 TD5 Defender 90 xs station wagon
Post #478909 3rd Dec 2015 11:03pm
Mole grips attached to the underside will stop the rivnut spinning and once the bolt is out use your rivnut tool to tighten the rivnut, then use copper slip on the bolts going back in.
Top tip, remember to retrieve the mole grips afterwards Mr. Green
The floor plate is still removable but you probably won't be able to get to the fittings with the cubby in the way
Post #478964 4th Dec 2015 8:18am
RRUK
Thanks Chaps Thumbs Up
nothing ever goes back on without copper grease. 2016 D4 HSE
Post #479006 4th Dec 2015 11:53am
Hufflepuff
... and guess what I forgot the last time I did this. Thankfully after 100 miles up the M3/M25, they were still attached Very Happy
Post #479034 4th Dec 2015 1:41pm
alexatnd
Good tips,
Was planning on taking the cubby box out to get at the filler 'oles for gerbox and transfer box on Effie our 2004 which came with cubby box fitted.
I fitted a cubby box to gertie our 1999 td5 110 but only used bolts at the time. Thought it would be a good idea to rteplace bolts with rivnuts. Can anyone recommend a rivenut tool to purchase. What sort of price are we talking about?
A Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Gertie - 1999 110 TD5 - new chassis etc back on road
Effie - 2004 110 TD5 County
Post #479681 6th Dec 2015 5:54pm
NormanD
England 2015 Defender 110 Puma 2.2 USW Santorini Black
Not cheap, but it works for me:-
http://www.memfast.co.uk/shop/Vprod1.asp?cat=2258004632 NormanD WE191
2015 110 XS Utility
2014 VW Caravelle 180 Executive
Post #479692 6th Dec 2015 6:11pm
Barney12
I have this one. Works well but a bit bulky:
http://www.amazon.co.uk/Laser-3736-Heavy-D...t+nut+tool
Post #479784 6th Dec 2015 9:20pm
