Home > Maintenance & Modifications > Front lights without clutter
Page 3 of 3 <123
BuckBlu110
United Kingdom 1994 Defender 110 BMW M57 3.0 Diesel CSW Buckingham Blue
^^ Don't suppose you have a link for those finishing rings/trim do you? Can't seem to find them on their website.
Post #478261 2nd Dec 2015 9:19am
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
Thanks again LR90XS2011, I've seen the loom with an original L/R switch for £99, seems expensive but that looks like the best option to go for in my case, I'm not too fussed about having DRL's to be honest, I'd prefer to be able to turn on some extra spot/fog lights as and when needed. Cheers again.
Post #478282 2nd Dec 2015 11:05am
LR90XS2011
http://api.viglink.com/api/click?format=go...inbauringe
perhaps Brendan Leeds can help
Leeds sells Nakatenenga stuff, although I ordered mine direct,the driving lights filling the holes are Ring from Halfords they do fog as well, there are round DRLs the correct size which from memory was 70mm
http://nakatanenga-tours.de/shop/catalog
http://nakatanenga-tours.de/shop/article_EBRSC-PB/Einbauringe
http://nakatanenga-tours.de/.media/235287863105.png
http://nakatanenga-tours.de/.media/123318022979.png
http://www.defender2.net/forum/topic15026.html
I used Ring driving lights in my bumper and Nak finishing rings (which like all Nak stuff were expensive but well made) I considered fog lamps nearer the ends of the bumper which I thought would be legal but realy wanted more light for country lanes not for fog.
I drilled all the holes in the bumper myself except the 4 big ones but only because my piller drill was too small I brought a cutter 2mm bigger than Nak recommends and slipped the local engineering firm £20 to drill them for me. Im very happy with the asthetics. As I used the standard LR spot light loom I changed the 55w lamps to 35w but they still make a big difference, If I had 55w in each lamp which would defo need a bigger fuse and possible be outside the standard LR loom wire capability Im sure the Improvement would be even greater
total cost was
Genuine LR loom £120 with dash switch (Paul on here does them made to order much cheaper and with thicker wiring if required)
Driving lamps are Ring from Halfords circa £25 for 2 (see the NAK site they use Ring as well and list DRLs for this application)
Tank cutter and arbour circa £20 (starrett) there are cheaper makes
Labour for cutting holes circa £10-20 or do it yourself if you have a big drill
Nak rings circa £80 (check the NAK site memory poor)
Plugs to fit onto lamps that match LR loom circa £5
Stainless nuts bolts and washers for mounting circa £2
to be fair the finish on the holes in the bumper was brilliant and a bit of paint on the exposed metal would have negated the use of the rings, if I was doing it again I might save a bit of cost there
where I put mine gave me a number plate issue and the position shown of the photo was a temporary fix. Fog lights and DRLs need to be towards the ends of the bumper. DEFENDER 90 TDCI XS,
Post #478519 2nd Dec 2015 10:07pm
Lambley
^^^^^ Thanks again, much appreciated.
I've spoken to Boltonbits about some bezels, they sell the ones below for £15 each and lights at £25 a pair. I've managed to get a genuine LR auxiliary lighting kit and switch from a member on here.
I think I'll get a pair of spots and a pair of fogs, wire the spots to come on with main beam and the fogs to come on with the aux switch.
Post #478662 3rd Dec 2015 11:08am
capnjapseye
United Kingdom 2016 Defender 90 Puma 2.2 HT Santorini Black
Nice one Lambly, looks like a good solution at a decent price, can you point me in the right direction for a loom / switch setup?
Cheers 2015 90 Hard Top
1998 90 300Tdi - chuffed to have another one
2013 Freelander 2 - for posher trips to the shop
1996 300 Tdi 90 Hard Top - sold 19th June 2020 - miss it, loved it
2016 90 Hard Top - demolished Nov 2019 by young driver 3.5 times over the drug limit
2010 90 Hard Top - now sold
Ex mil 90 - now sold
Post #479170 4th Dec 2015 8:37pm
Lambley
I guess it depends how you want the wiring etc, I think I'll opt for fogs wired to an O/E switch mounted on the dash for the fogs and the spots to come on with the main beam, probably not the cheapest way to add bumper lights but I'd like to do it properly, there are probably other ways of doing it but this is what I've found so far .....
http://www.ebay.co.uk/itm/230884413951?_tr...EBIDX%3AIT
http://www.ebay.co.uk/itm/231667066535?_tr...EBIDX%3AIT
Post #479193 4th Dec 2015 10:15pm
LR90XS2011
result, they look nice , might buy myself a take off bumper and have a play DEFENDER 90 TDCI XS,
Post #479233 5th Dec 2015 2:14am
Gazngoz
Lambley,
Good find. Those lights are just what I have been looking for. I went straight to the boltonbits eBay store after reading your post but I can't find them. Do you have a part number or anything please ?
I've been looking at mounting lights in my bumper for a while. Posts on various forums have referred to needing heavy duty pillar drills to cut the holes, others have referred to just using a tank saw with an electric hand drill, a cutting disc on an angle grinder or even a jigsaw. Can anyone whose done this shed some light on how difficult the cuts are please.
Thanks,
G
Post #487323 31st Dec 2015 7:14pm
Lambley
Gazngoz - my eyelids are stuck together this morming and my brains not in gear yet but - I'd call Boltonbits and ask to speak to Joe (female), she gave me the prices etc when I called, I didn't get a manufacturer but she told me they're the lights they use in their own bumpers.
As for the holes, I've not got that far myself yet, still deliberating, but I was going to just get a 76mm bi-metal hole saw and drill it slowly, but I might end up doing this instead.... Suggested by 'wild card 90'
With hells ff75's mounted under the bumper....saves drilling etc....
Post #487453 1st Jan 2016 10:42am
Gazngoz
Thanks mate. I was planning to contact boltonbits but new year and the weekend were getting in the way and I was / am impatient Cool
Those hella look good but my preference would be to go in the bumper rather than under. I know hella used to do some nice flush mount oval lights but they must be discontinued as I can't find any online.
Thanks for reply and happy new year
G
Post #487511 1st Jan 2016 2:52pm
ericvv
bpman wrote:
This provides a flexible lighting option, fogs, low/high with spots and a light bar for the really dark bits
Having seen it real life, agree it is all stunning what you did there, especially the 90mm aux high beam LED conversion which seems one of a kind. Thumbs Up
But,.... the ""fogs""? Confused Mmmmhhhh, not sure they would pass the MOT here under that denomination.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #487537 1st Jan 2016 4:33pm
Pickles
LR90XS2011 wrote:
4x ring driving lights inside the bumper, fogs can be fitted at the ends
TOP JOB,...very neat instal,...looks factory.
Pickles.
Post #487658 1st Jan 2016 10:52pm
Page 3 of 3 <123
