Home > Puma (Tdci) > Change into 2nd
Jonno
United Kingdom 2011 Defender 90 Puma 2.4 HT Santorini Black
Change into 2nd
Having moaned about my Defender 2.4Tdci gearchange into 2nd I have been giving it some more thought and been doing a bit of experimenting.
It seems that revving to nearly 3k eases the shift into 2nd. So i'm thinking the issue with the gearchange is a mismatch of gearbox and engine speeds and potentially weak synchros.
I have heard people talk about their Defenders having an annoying rev hanging issue, mine doesn't seem to do this, however if I keep the revs up by pressing the throttle it does help it slip into 2nd.
It just seems counter productive revving hard in 1st unless towing as 1st is so low geared!
So after thinking about this, I'd quite like a defender that hangs its revs.....
Jonno
Post #478100 1st Dec 2015 8:37pm
LR90XS2011
mine was a bit rubbish it got loads better after I had the clutch and transfer box adaptor shaft changed at 11k miles DEFENDER 90 TDCI XS,
Post #478105 1st Dec 2015 8:44pm
A fluid change makes a good difference, especially when cold.
Post #478147 1st Dec 2015 10:00pm
Simon27
Scotland 2009 Defender 90 Puma 2.4 SW Tamar Blue
Yes, I have to rev the same amount to get a smooth change into 2nd, but that's also to give me enough time/momentum for a slow gear change.
Planning an oil change soon as it's got noticeably worse in the recent cold mornings.
Post #478157 1st Dec 2015 10:11pm
YOLO110
Australia
Both mine gave a 'nick' when going into second... more pronounced when cold but still there a bit when hot...
Is the a 'TADTS'?? Question YOLO... You Only Live Once...
Post #478212 1st Dec 2015 11:51pm
