Home > Puma (Tdci) > Richard Chassis on Puma
bartv
Is a Richard chassis approved by Land Rover as a replacement chassis for a Puma?
Anybody ever swapped a chassis on a Puma?
Post #47754 7th Dec 2010 8:18pm
T1G UP
Re: Richard Chassis on Puma
bit new, lr only i'd say
Post #47755 7th Dec 2010 8:22pm
bartv
What does a LR chassis cost?
Post #47756 7th Dec 2010 8:27pm
Puma 90, from vin 9A onwards, LR015410 £2807.96
puma 110 " " " LR015411 £2794.64 (yup, it's longer, but cheaper!)
Puma 110 HD (HD rear spring mounts, maybe some chassis plating) LR015409 £4094.93 Shocked Shocked
puma 130 LR015412 £4094.93 (yup, same as a 110 HD)
(this is LR prices, not Richards)
Post #47794 8th Dec 2010 8:52am
mse
Other than a major accident...why would you bother Question Mike
Post #47795 8th Dec 2010 8:56am
bartv
Major accident is the reason Smile
http://defenderrebuildproject.blogspot.com/
Post #47799 8th Dec 2010 9:27am
LCJ
Great project, thanks for the link. I'll watch that with interest. Good luck!
Post #47809 8th Dec 2010 10:43am
Grockle
if it's a right off how does the warranty stand anyway 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #47810 8th Dec 2010 10:43am
Zagato
It's incredible to see a Puma stripped down to the chassis and realise that the chassis and shell are almost the same after 50 years. Shame you cannot use the Richards chassis, they are very good. This is a pic of the same model as yours but it is a 1968 Station Wagon. I am just waiting for new doors. I envy you being able to buy all the parts you need off the shelf. It's the only thing that is holding up my rebuild.
Good luck with your Puma rebuild and keep the pics coming Thumbs Up
Post #52979 14th Jan 2011 5:41pm
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
Great pic of your restoration Zagato!
You could post some more, and keep us up to date in the off-topic section! I'd love to see process! Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #53029 14th Jan 2011 9:11pm
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
Dont marshland make them for land rover or something like that? Could be mistaken but ive sure ive read something alone those lines before? Im 100% sure they build the chassis the same as land rover though, the rails are 2 pressings welded down the middle. Not sure if im right but dont richardson's weld 4 pieces of flat together like the SWB series chassis used to be made?
Pete
Post #53031 14th Jan 2011 9:20pm
Zagato
Yes lrmaniac I'll post some pics up for you Thumbs Up
Marsland no longer make Series LR chassis they are concentrating on Defender ones!
Post #53099 15th Jan 2011 2:05pm
TallPaul
Assuming its the same Zagato its worth reading the whole thread on the series2 forum Very Happy
Marlands definitely make TDCi chassis now, would assume Land Rover manufacture their own though? Disco 3 gone but the memory of the bills remain...
XS 110 Utility maybe one day..... (did they fix the quality yet?)
Post #53348 16th Jan 2011 9:10pm
defendertom
Wales 2011 Defender 90 Puma 2.4 SVX Soft Top Santorini Black
i am building an svx on galv chassis. seems pretty easy until i have to start it. having problems. tried putting diesel stright to it but still wont fire. does anyone know why it would wind over and not start. there is diesel to the injectors.
Post #54080 20th Jan 2011 10:44am
Lorryman100
Hi defendertom and welcome to the forum Thumbs Up
I saw your post on welcome to defender2.net and see it is a Tdci engine in the project svx. Did the engine come with its ecu unit? Is there a 10AS unit? One reason for not starting is if the injectors are not coded to the ecu, maybe problems with the immobiliser in the 10AS unit? Could you post more info on the install of the Tdci power plant including the electronics side?
Brian.
Post #54081 20th Jan 2011 10:52am
