![]() | Home > Maintenance & Modifications > Vibration after reinstalling front suspension |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3411 ![]() ![]() |
Have the new springs resulted in any lift at all?
Sometimes the front propshaft will end up running at too high an angle and give you the sort of vibration you're talking about. ![]() |
Branny Member Since: 16 Nov 2014 Location: Morzine Posts: 9 ![]() ![]() |
Hi Camelman,
No, standard height springs fitted - there was a bit of lift as the old springs were probably the originals on a 2004 vehicle. But it shouldn't have skewed the prop angle out of the normal operating angle... How can I check this? |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2767 ![]() ![]() |
Take the front prop off and go for a drive.
Fitting HD springs will give a lift in theory. |
Thanks for the advice Retroanaconda, will give it a whirl.
Whats the recommended solution if the prop removal does cure the vibration? new UJ's? or new prop...
Prop off. No vibrations. Thanks Retroanaconda - I'll do the UJs and see where that takes me.
Branzelous Member Since: 07 Oct 2015 Location: Seytroux Posts: 1 ![]() ![]() ![]() |
OK, after a while running in diff lock, waiting for parts to turn up a midst the xmas postal rush, I have reinstalled new front UJs. Prop back on, I am back to the same situation as before. Slightly reduced vibration, but still very noticeable.
![]() I cannot believe that I'm the only person that has fitted standard height Britpart heavy duties and experienced this problem... A friend who has fitted a 2 inch lift is running with a standard prop - he suggested it might be spring chatter. Not convinced. is this change in height really going to cause imbalance in the prop? Bushings? Any other thoughts welcome! |
I suspect it's due to your prop angle being slightly higher than tandard, perhaps due to all the different tolerances in the suspension adding up to a front diff that is already slightly 'out' from design angle. Then adding the HD springs the small lift that it introduces pushes it over the limit of what the propshaft will take without introducing a vibration.
The front prop is always more susceptible to vibration due to the fact that the joint angles are not equal (diff points upwards) and therefore the inherent vibration (rotational speed variation) that comes with UJ type joints will not cancel out like the rear propshaft does. This is why posher models were fitted with double-cardan joints on the shaft - to alleviate this issue. Defender owners have to suck it up! |
Pilgrimmick Member Since: 16 Nov 2015 Location: Highlands Posts: 582 ![]() ![]() |
Try the pan hard rod bushes, make sure the bolts are tight!
I had a similar ptoblem and spent ages trying to track it down. |
