![]() | Home > Puma (Tdci) > Emissions Results |
martinfiattech Member Since: 13 Nov 2013 Location: leicester Posts: 422 ![]() ![]() |
Vehicles first used after. 08. 2008. max emission value 1.50 m1 opacity figure.
So basically it`s ok. mine was 0.36 Excuse the spelling I`am better with spanners and wires. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20945 ![]() ![]() |
0.31 on one MOT for mine, another 0.33.
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
Can't remember the figures but my dads 1996 tdi fast passed on the smoke test the other week
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 ![]() ![]() ![]() |
Mine was 0.16 this time round, last year was 0.18,
![]() Funny enough, since last re-map [IRB410] it dropped from mid .30's to mid .teens - another bonus ![]() |
Well mine's not been run much recently, certainly no long runs and has just passed it's first MOT but with a reading of 0.90 m-1. It will have been a cold engine, in the sense that it had not just come in from a long run, it was stood at the dealer's for a couple of days before the test. obviously, it was run up to initial temperature before the test - results sheet say oil temp was 79-80 C.
This looks particularly high in relation to other readings posted here. Any thoughts on whether this is just as a result of lack of recent use or is there something I should be looking at? |
Lack of use usually does it as the soot gathers in the exhaust system. When they accelerate to the governor for the smoke test the soot is blasted out with the high gas flow and gives a artificially high reading. A good hard full throttle run in 2/3rd when warm will clear it out. Once mine is warm on the way to the test centre I hold it in 2nd till it hits the governor. Hasn't failed yet
![]() ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Cheshire110 Member Since: 26 Jul 2013 Location: London Posts: 2788 ![]() ![]() |
Mine has EGR blanked and remapped by Alive, and MOT people the other week said it was better than other defenders and commercial transits/diesels generally that they've seen. Cheers, David
Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
Same for me, never see any smoke at all not be honest.
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
Mines had a BAS remap, decay for about 30,000 miles now and it passed with flying colours. I do a lot of motorway miles which helps
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 ![]() ![]() ![]() |
My last one they said it failed the first test so they took it out for a "warm up run" and it then passed with flying colours
![]() Self confessed mileage hunter ![]() |
Do any of you have the results figures - I'm interested in seeing what the actual range might be.
It says in an earl post that the Max is 1.5. So 3.9 is low. I wish mine could blow a load of coal out like a smoke screen!
Jukathy Member Since: 25 Jan 2015 Location: Berlin Posts: 170 ![]() ![]() |
Smoke.
lohr500 Member Since: 14 Sep 2014 Location: Skipton Posts: 1343 ![]() ![]() ![]() |
Would that pick up be in the same country that is so cut up about the VW cheat software?
