Home > Maintenance & Modifications > Leak between tub and sides
Cupboard
My Defender leaks between the tub (the pickup bit) and the sides (the hard top bit). At least, when it rains hard I get a puddle on the wheel arch box, the sides above the join aren't wet, there's water obviously sitting inside and now I've taken the sides off the roam is wet in a few areas.
I have the roof off to get it resprayed, and have taken the side off to have a look. In order to stop it leaking, what is my best option? Replace the foam bit? (Is that going to be silly expensive?) Run a bead of sealant along before I but the sides back on? Try and bolt the sides down tighter? Something else?
Post #477002 28th Nov 2015 2:13pm
Brewstop
United Kingdom 2002 Defender 110 Td5 CSW Zambezi Silver
I would inspect and replace the foam seal if required, then use a tall bead of Innotec Adheseal or similar to seal the joint.
I've just refitted my body cappings, sides and roof using Adheseal and its really good kit.
http://www.innotecworld.com/products/seala...oductid=29 Sandy
Post #477007 28th Nov 2015 2:37pm
dorsetsmith
Re: Leak between tub and sides
as above but with LR part no STC 3289
AML710050 seal lower LH AML 710040 seal lower RH 110 HT
Post #477012 28th Nov 2015 3:10pm
dave18
United Kingdom 1984 Defender 110 300 Tdi CSW Portofino Red
Mine does the exact same so used sealant along the outside edges to cover the foam!!
Would definitely replace the foam so you know it's good and as said add a good bead top and bottom
Post #477083 28th Nov 2015 5:09pm
