Home > Maintenance & Modifications > Front lights without clutter
Page 2 of 3 <123>
leeds
LR90XS2011 wrote:
are lazer lamps legal in the ends of the bumper?
Short answer YES.
As long as they are E marked which ST4's are and wired in so they go off when main beam is switched to dip.
Only requirement is that the outer edge of an optional light should be no closer to the outer edge of the vehicle then the outer edge of the obligatory vehicle headlights.
Brendan
Post #476923 28th Nov 2015 9:46am
LR90XS2011
Brendan thanks I may buy another bumper and move 2 of my lights towards the ends rather than the middle then DEFENDER 90 TDCI XS,
Post #477183 28th Nov 2015 10:00pm
Ahmed
Bahrain 2015 Defender 90 Puma 2.2 SW Aintree Green
This is what i did ..
Post #477246 29th Nov 2015 9:22am
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
Hi LR90XS2011
When do you light come on? I've do they come on with full beam, headlights or are they set up a DLR's?
Ideally I'm after something that comes on with full beam only just to give a brighter light, or as spot/fogs on a separate switch on the dash
Ahmed, that front end looks great, I wish I had more £££'s Big Cry
Post #477273 29th Nov 2015 11:09am
This provides a flexible lighting option, fogs, low/high with spots and a light bar for the really dark bits
Post #477276 29th Nov 2015 11:22am
MuddyChris300tdi
United Kingdom 1995 Defender 130 300 Tdi HCPU Alpine White
I fitted these to my Disco. Ok there won't be as bright as the lenzer but for £40 each they add more than enough light.
But any (flood) light won't be any good in fog as they light everything up. Maybe better to have floods on top of the bumper to come on with main beam and then some fogs under the bumper on a separate switch.
Post #477359 29th Nov 2015 3:29pm
Lambley
I didn't get time to call Devon4x4 today but I'm wondering about altering a bumper, either my std one or a new one from devon4x4, cutting / drilling some holes to fit some lights into the bumper, these look about the right size, they could be mounted either on the front side or inside of the bumper for £25 and are small enough to fit...
http://www.ebay.co.uk/itm/401031235439?_tr...EBIDX%3AIT
Or round ones, or just buy one from Bolton Bits....
http://www.ebay.co.uk/itm/391247644740?_tr...EBIDX%3AIT
Post #477740 30th Nov 2015 6:55pm
Hairysteve
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Barolo Black
Like this?
Post #477773 30th Nov 2015 8:35pm
Lambley
Yep, just like that. What are they? Are they wired as spots or drl's Steve?
Post #477780 30th Nov 2015 8:45pm
Hairysteve
These are wired as DRL's but would easily have spots if wanted.
Come from here https://www.mobilecentre.co.uk/index.php?m...cts_id=543
Steve
Post #477786 30th Nov 2015 8:52pm
Merlin
To keep the front really simple, just use the side lights as side/DRLs by incorporating a 5/21w light (LEDs are perfect). This is just a rear stop/tail mounted on the front with a clear lens. That's my solution and it's legal, simple and cheap.
Merlin
Post #478173 1st Dec 2015 10:45pm
m33ufo
Wales
I like that a lot.
Post #478178 1st Dec 2015 10:55pm
leeds
Sorry Merlin, but I am not sure that I fully understand what you mean.
For a start all vehicle obligatory lights have to be type approved or E marked.
Now all legal lights have a code on them which designates what they are used for.
A front side light or position light is marked A on the lens
A rear position light is marked R and a brake light is S1 whereas the third/high level brake light is marked S3.
I would question the legality of using a lamp designed as a rear stop/tail light on the front of a vehicle even if it had the correct coloured light fitted to it.
Now taking a 5/21 watt filament light bulb out of a light unit and fitting a LED device in its place is illegal.
The reason being that in the homologation of the light it should be specified what type of bulbs can be used. I have checked with two major European light manufacturers and they stated that replacing any filament bulb with a LED would invalidate their E marked approval
If I have misunderstood what you have proposed then I apologise.
Brendan
Post #478194 1st Dec 2015 11:19pm
PCA42
England 2008 Defender 110 Puma 2.4 DCPU Tonga Green
Standard Chinese LED flood/driving lights mounted directly onto the top of the front bumper. I'd love Lazers, but can't justify the cost atm. They work well for what they are, fill the void between the front of the truck and the main beam, plus light up either side nicely. Wired in using the genuine LR auxiliary lamp harness kit, with toggle '2' switch on the dash.
 Pete
2010 Discovery 4 GS TDV6
1972 Series III 88" 2.25P
Post #478224 2nd Dec 2015 12:59am
LR90XS2011
[quote="Lambley"]Hi LR90XS2011
Hi Lambley
mine are switched via a genuine LR auxiliary lighting kit and switch and can come on with the high beam when the auxiliary light switch is on or not if it is off, I therefore cant switch them on independently to the high beam. I currently have 2 off 55 watt bulbs and 2 off 35w bulbs fitted, and the LR components seam happy with this.
Some peps on here suggested that having the lights this low creates shadows, but for road use I have never noticed this I have set them so 2 light up the verges and 2 the distance. I also have uprated headlight bulbs and the uprated loom with relays so my headlights are very bright but these lights still make a very noticable difference especially around the fringes of the headlight. Aesthetically I think if I did it again I would fit them below the headlamps but the rear of the bumper picks up loads of water and mud from the front wheels, in this position they stay pretty dry except when fording. I have had to seal the rears of the ring lights with silicone to stop water getting in but this only happened when I have been through a ford. My finishing rings came from Nakatenanga but you dont need them if you are neat with your tank cutter, I could have just repainted the cut edge on mine as the bumper drilled out very neatly.
One thing I have noticed is this mod is always commented on favourably by other LR owners when they look at my car. DEFENDER 90 TDCI XS,
Post #478243 2nd Dec 2015 7:38am
Page 2 of 3 <123>
