![]() | Home > eBay & Bargain Spots > 37" wheels |
| Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
Think from the look they may have been a bespoke set made by Matt Lee. Hence the reason they flew.
| AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3709
Probably not road legal what do you reckon?
Matt made me a set of 18's and they are not stamped with any codes or numbers. As a result I am reluctant to use them |
The two sets I had one from D4X4 and the second from a forum member didn't have markings either. Could be they had been covered up by the coating process not sure. Hasn't stopped me from using mine as only the beadlockers he used to make were advertised 'not for road use' they were also notoriously difficult to balance if you did intend to use them on-road. If you go through life with your head in the sand....all people will see is an ar5e!!
| MuddyChris300tdi Member Since: 02 Mar 2014 Location: Derby Posts: 225
What would make them a special and not road legal?
They are not stamped with a load rating. 130's have feeling's as well you know
