![]() | Home > Td5 > Front door seals (lower) |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6023 ![]() ![]() ![]() |
Today I finally got around to replacing the lower door seal on the drivers and passenger doors.
On opening the door, the door now feels more springy than before, so hoping its a good seal. But.....there is still a gap which I can see daylight through (circled) ![]() Click image to enlarge Which seal am I missing to stop A) Daylight B) Draught The daylight is the corner of the door where it meets the sill/B bottom of the B pillar The seal I fitted was http://www.ebay.co.uk/itm/Land-Rover-Defen...SwrklVbvs~ (Gen LR part) 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
your missing these
two per door
One each corner, B pillar and A pillar? Stuck to the door or to the body work ? 1999 Defender TD5 110
One each corner, B pillar and A pillar yes
Stuck to the door |
Excellent - cheers. 1999 Defender TD5 110
As a side note just ordered new rear door seals but have gone for the later Puma style ones as they look better than the L shaped rubber strips. I might consider doing the same to the front doors as well.
Just wondering, do the later Puma seals negate the need for the foam pads? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
driver9 Member Since: 15 Oct 2012 Location: Suffolk Posts: 111 ![]() ![]() ![]() |
Simple answer yes on a Puma not sure about a TD5.
no because they have side rubber back and front but to fit them on older door isn't an easy job !
see below ![]() |
Cheers Driver 9
What makes it a difficult job to fit these seals to a Td5? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5138 ![]() ![]() ![]() |
Some good info on fitting the later seals to TD5's here
http://www.defender2.net/forum/topic6370.h...door+seals For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
CDN38 Member Since: 14 Nov 2014 Location: Courtenay, BC Posts: 729 ![]() ![]() ![]() |
Step by step instructions
http://defender90xs.blogspot.co.uk/2014/08...seals.html |
Cheers I will have a look. 1999 Defender TD5 110
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1789 ![]() ![]() ![]() |
Might have to get a set of those! Need to replace all the metal at the bottom of the door first though...
