Home > Maintenance & Modifications > footwell leaks - bulkhead is OK dealership claims
Page 1 of 3 123>
Giby_off
Bulgaria 2012 Defender 110 Puma 2.2 SVX Station Wagon Havana
Help needed. There is constant water in the footwells. Isolation foam in the front under the foot is always wet.
Dealerships claims the water is not coming from the bulkhead seal.
Any suggestions?
Post #476331 26th Nov 2015 12:50pm
keith
Windscreen . Guaranteed. Take out the window and use sealant top and bottom corners . Thumbs Up
Post #476382 26th Nov 2015 2:47pm
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
Not necessarily windscreen foam, could be the windscreen brackets as well (I reckon it's a very common source of leaks).
I replaced mine along with the gasket and applied sealant inside the fixings on the bulkhead and no more leaks for me.
http://www.landroverworkshop.com/diagrams/...reen_52775
Get the dealer to fix those now, or else you'll have to fight another battle with corrosion warranty sooner than you expect.
Post #476394 26th Nov 2015 3:42pm
adamatdraycott
United Kingdom 2014 Defender 90 Puma 2.2 SW Corris Grey
Corner of the windscreen seals.
If you pull the seal into the windscreen frame you can often solve the leak for a while.
I occasionally get a small dribble onto my passenger mat. Have since pulled the seal onto the frame and taken it to the dealer for an investigation. They tested it in their facility for 4 hours and it was dry inside!
Post #476409 26th Nov 2015 4:29pm
keith
04dn
I never mentioned foam . There is no foam around window .
The water IS coming in the flat edge of the metal frame under the seal . I'll put my wages on it . Whistle
Post #476427 26th Nov 2015 6:32pm
Happyoldgit
TBH at the risk of being branded unhelpful the OP would be best served by reading and inwardly digesting some of the many, many previous threads on the eternal subject of leaking Defenders. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades.
Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone.
http://forums.lr4x4.com
Post #476435 26th Nov 2015 7:01pm
Giby_off
Thank you for trying to help. The dealership checked also the windscreen brackets. I will try to check by myself if the water is going trough the windscreen seals before I go to the dealer. It is strange because on the picture you can see that the water traces are in the middle of the car.
Post #476436 26th Nov 2015 7:04pm
The wet bits may well end up in the middle but usually where they end up isn't a gret indication of where they started. There are many fittings, brackets, and other odd shapes on the bulkhead panel which will direct the water into a completely misleading place.
For what it's worth I agree with what has been said above. The first place I would suspect is the seal between the glass and the frame, the second the seal between the frame and the lower bulkhead. Both of these joints are notorious for leaking.
If you look in some of the threads with photos taken on the productin line you will see pictures of the special test facility for leaks. This is a thing like a giant car wash that Defenders are taken through in order to make sure that they leak properly, and that a dry one doesn't accidently leave the factory. Rolling with laughter
Post #476443 26th Nov 2015 7:22pm
Giby_off
When you talk about corner of the windscreen seals, do you mean that shown on the picture?
Here is the window to bulkhead seal. Dealer did not replaced the seal but used windows silicone to seal it.
I can not see a hole.
Post #476472 26th Nov 2015 8:55pm
T1G UP
The return lip ends where the hinges are. The water runs through the seal, its porous, end down where the hinges bolt through. Then down on to the boat of the dash. I know this because mine does it. I have just bought a second hand tdci bulkhead which also had the same issue. It's been galvanised and will be fitted along with the galvanised b posts I have. The dealer cannot really fix the issue. The best way is to seal the front of the bulkhead to screen seal with mastic.
Post #476477 26th Nov 2015 9:00pm
dave w l
England 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
Surly it's up to the dealer to solve the problem not us my 2014 defender 90 is going back in for the second time . There is a brown stain running down into the near side foot well so I'm going to insist that the bulkhead should have some sort of rust prevention treatment done after they solve the problem. I want a full waxoil done but there's know point until the problem is solved what do U guys think . Stay safe
Post #476497 26th Nov 2015 9:20pm
Alphabear
Wales 2015 Defender 90 Puma 2.2 HT Scotia Grey
I have a rusty stain in the footwell also. Booked into the dealers next month but I had also wondered that if they fix the leak what is going on behind the dash where the rust is coming from? Anyone taken this up with LR?
Post #476541 26th Nov 2015 10:38pm
Giby_off
When I fix the water leaks issue I am planning to fix rust problem by myself. For such kind of things I can not trust them.
They can not stop water leaks also.
Post #476612 27th Nov 2015 7:36am
o4dn
You might want to show this manual from Land Rover to your dealer:
http://www.productmanualguide.com/water/de...anual.html
Granted, it's for older models, but the design hasn't changed much since then! Rolling with laughter
Post #476625 27th Nov 2015 9:15am
VeeTee
Netherlands
Read the chapter on "Footwel leaks" in the Land Rover Defender Water Ingress Manual.
Your picture indicates clearly the wayer is not coming from the bottom or seams im the footwell but from higher up in de firewall. There may be leaky seams between the windscreen surround and firewall, window blocks, ventilator flaps, or leaky spots or grommets were cable looms etc. enter the cabin.
 Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #476627 27th Nov 2015 9:22am
Page 1 of 3 123>
