Home > Other Site Sponsors > [For Sale] PUMA overheat? We have the cure!
Page 3 of 4 <1234>
Eduardo
Now is winter here, but I hope that in 6 month more the device will be proved.
At least is less expensive than change the radiator for a more efficient one.
Cheers Eduardo
Post #443357 5th Aug 2015 12:26pm
smb
If it helps to reduce the top end of the temperature scale then it has got to be vital for those with accessories that restrict the airflow. i.e.. High or low mounted winches, A-Bar mounted spot lights, radiator muffs, steering protection plates, etc...
When will Brendan/Barbara be stocking these?
Post #443363 5th Aug 2015 1:15pm
bittersweet
2009 Defender 110 Puma 2.4 USW Santorini Black
YOUR wish is my humble command, Lord Razz Laughing
According to the packing notes they are in the consignment that were delivered this afternoon. Not unpacked yet Whistle
Brendan www.4x4overlander.com
Post #443776 6th Aug 2015 5:09pm
leeds
I don't know he manages to log in as me when I can't log in as me and have to steal his login Snigger
Barbara
Post #443782 6th Aug 2015 5:21pm
smb
This simple mod has got to be ideal for all those towing.
For the last 4-5 months my 2.4Tdci has been Safe Mode whenever I towed up a hill, cruised at 70(or maybe just above Wink in which case it was a bl..dy good way of stopping me speeding!!), or even normal driving on a hot day(not that that happened much!)
It may also be the cure for those with air restrictions mounted on the front that occasionally trigger the safe mode.
Anyway, Brendan/Barbara performed as they usually do and got me mine the following day. Half an hour later, all done.
My Defender hasn't triggered Safe Mode since. From 10-15 times per day(on long journeys to London or Plymouth and back i.e.. 4-600miles in the day) to absolutely ZERO.
Another Brilliant, Simple Mod that Landrover should have done in the first place. WELL DONE Nakatanenga Thumbs Up Bow down Thumbs Up Bow down and of course Brendan & Barbara Thumbs Up
Post #453635 9th Sep 2015 2:02pm
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
So here is my own experience.
I fitted this spacer on my Defender 90SW 2.4 Puma MY2009 (without aircon) with 85k (km) on the clock planning a trip to Andalusia, knowing there are quite a few long stiff slopes on the motorway and the outside temperature is fairly hot over there (between 30~35 degs Celsius).
My car has never experienced power loss nor reported overheat before, but I did notice some small coolant loss in the past during summer that can indicate a rise in coolant temperature - Having a Scanguage fitted, I also noticed coolant temps getting quite close to 100 degrees in some cases. So fitting this spacer was more of a preventive measure for me.
Back from my trip, I can say I've seen the coolant temp reaching the 100 degrees mark on a few occasions, driving at high speed (for a Defender) and fully loaded (4 people with their stuff in a 90), and the expansion tank still shows trace of coolant escaping through the cap (cap is new, replaced 3 times already).
So all in all, it may improve things but it's not "the" cure IMHO, it certainly helps yet I doubt it can be considered a complete solution to the problem of overheating. As munch90 noted earlier in this thread, it won't drop the temperature below what the thermostat allows.
For a more complete solution, I reckon one would need to change the thermostat as well, as covered in another thread.
Anyway, the Defender has been completely faultless during this ~2500 kms trip.
Post #453642 9th Sep 2015 2:41pm
Eduardo
Summer is near and as 3rd measure (change the Intercooler and change the thermostat) I bougth the spacer to try with it during summertime.
So, I will check if improves the temp.
Currently temperature varies between 80-90°C in the city and between 90-100°C in the highway without load it. With load can go over 100°C.
The other day the Defender entering in safe mode (at 145 kph in a long slope is predictable I guess Embarassed )
Cheers! Eduardo
Post #476099 25th Nov 2015 4:38pm
T1G UP
must have a super rad fan or something in mine. it nevers moves!
also it cools down very quickly when ticking over with the heater on.Got a fix for that Nakman
Post #476110 25th Nov 2015 5:23pm
ericvv
Tig, X2 Thumbs Up I always understood a Puma has an oversized cooling system in the first place, and mine does the same as yours. I have been driving this summer in rather extreme 38C heatwave conditions for several 100km at length at continuous 120kph, and coolant temp meter stays rock solid just under the middle. The fan blows when stopping for a pause, but coping well with getting rid of any heat. Now, I do have the PEL500110 as well as the larger Entreq intercooler, but also my standard map. I suspect that a lot of Puma overheating problems come from mapping, more power means more heat production I think.
Now that we get frost the last week or so, the PEL500110 makes no difference to time/km needed for engine warming up. So thermostat may open at lower temp than standard, but warm up is the same, only engine will run more in the 80's than in 90's or higher.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #476130 25th Nov 2015 6:37pm
T1G UP
mines running a BAS map for the last 30,000 miles.
towed a 20ft trailer with an e class merc and a new 110 chassis for 200 miles this summer and never moved? I did have the a/c on which helps the cooling.
Post #476133 25th Nov 2015 6:55pm
redline
Switzerland
As I understand it, the spacer only benefits at low speeds, when the air mass flow rate is governed by the fan "pulling" air through the radiator. At higher speeds, the fan is "redundant" as airflow is governed by the vehicles forward motion "pushing" air through the radiator.
In any case; with the spacer fitted, my impression in warm (+30degC) conditions, under moderate load in slow moving traffic, it is having a positive effect. Although its impossible to recreate exact conditions before and after fitting, the scangauge readings seem to show temps running 5-8degC cooler. I can't see any downside to the spacer, so from my perspective its a no-brainer for those in warmer climates.
Post #502797 9th Feb 2016 8:08pm
Eduardo
My impression after install the spacer:
I running the Defender with and without the spacer under the same conditions (temperatures of 30 to 37°C in the same highway) with the air conditioning on.
Without the spacer, temps goes in the range of 95-96°C in most of the trip and reach 116°C (LIMP mode) in one opportunity in a gentle slope.
After 3 trips with the spacer installed seems the temperature was decreased to 90-96°C and in the slope reach 105°C.
Appears that the spacer have an effect of 5-10° less, enough to avoid the limp mode in the normal driving, at least in my case.
Cheers! Eduardo
Post #509700 1st Mar 2016 8:46pm
nakatanenga
Germany
Great to hear! This shows, that the spacer is working WANTED:
SII or SIII in max 1.5k
Post #513221 11th Mar 2016 4:04pm
dgardel
Italy
First, the spacer move the fan where it should stay. The original position is outside the duct and in this way the fan loose tons of efficiency.
Second, the 2.2 engine has new visco coupler with with a longer connecting sleeve/shaft (yes LR copied the idea) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #650520 15th Sep 2017 8:31pm
MK
The male thread looks normal, but is the female side reverse thread? Question Puma 110" SW
Post #669527 7th Dec 2017 1:14pm
Page 3 of 4 <1234>
