Home > My Defender > My new (to me) Defender 90 Puma
Page 18 of 34 <123 ... 171819 ... 323334>
JDH
United Kingdom 2012 Defender 90 Puma 2.2 HT Santorini Black
Hi Adam,
I have also just had my dealer on the phone! They are also replacing my entire clutch unit under warranty as a result of the chatter from the deep... I've heard it's either a broken or loose Spring on the clutch plate or some kind of release bearing, turns out the fault with mine was 2 loose springs rattling around. They also have to keep it in for a further three days after to replace pretty much every seal on the truck as when it rains or gets pressure washed the puddles on the inside or bigger than the puddles on the out side! Rolling with laughter
Thanks for getting back to me Thumbs Up
Post #476055 25th Nov 2015 1:34pm
RRUK
A good result all round Thumbs Up 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #476062 25th Nov 2015 1:55pm
JDH
Absolutely, glad they just got on with it and admitted there being a fault and it was to be repaired under warranty rather than trying to wriggle out of it in anyway.
Post #476064 25th Nov 2015 2:01pm
Windowlicker
United Kingdom 2011 Defender 90 Puma 2.4 HT Stornoway Grey
Fair play , mine had rattled from day one of my ownership too , I just assumed it was a " defender thing "
Having read into on this fine forum I decided to have it addressed for peace of mind.
JAS who did it , had done another prior to mine which was newer but higher mileage, one of the springs had cone adrift and gone into the pressure plate. "Procrastination is the thief of time"
Post #476072 25th Nov 2015 2:16pm
YOLO110
Australia
RRUK wrote:
The Defender is in the Dealers today to have the clutch rattle investigated.
Fingers crossed, either way it will come out with a new clutch.
Result mate! Thumbs Up
That's also a neat way of getting it valeted after all that mud!!!! Laughing YOLO... You Only Live Once...
Post #476081 25th Nov 2015 2:51pm
RRUK
They even sent me a video by email of my Vehicle Health Check - as there was nothing to report he went round showing the tyre depths, I could see it has been jet washed but not as thoroughly as I do it after each shoot, probably just enough not to trash their workshop! 2016 D4 HSE
Post #476093 25th Nov 2015 4:13pm
RRUK
Now I know I am not paying for the clutch my next modification can be triggered....
Ooooh, come to Papa.....
 2016 D4 HSE
Post #476129 25th Nov 2015 6:32pm
g-mack
they are stunning!!!! much better going than the recaros IMHO Shocked My 109 thread
my youtube channel
Post #476138 25th Nov 2015 7:19pm
JDH
Adam
Looks like our next purchase is going to be the same! heated corbeau's with white cross stitching and matching tall cubby box.. good minds think alike Thumbs Up i saw some in the flesh at the LRI warehouse that they had fitted in a very tidy 90 and they look and feel even better in the flesh! are you going for low or high base out of interest? I'm not overly sure on the difference between the two. on my current standard seats i have seat raisers from mud products so if the high base corbeau's are just slightly higher then i will most likely go for them.
Post #476270 26th Nov 2015 8:57am
RRUK
I am going for low base.
Not sure if I have understood what you are saying - but the high and low base variants talk to the seat base sides, not the height of the actual seat.
I'm going for the low sided base because even I tend to slide out of the car, rather than lift a leg out and climb out. In time, the high sided base would either become a PITA or get squashed and ruined.
If you look at the LRI site you can see the difference between the two.
(Apologies if I just did a sucking eggs lesson!) 2016 D4 HSE
Post #476283 26th Nov 2015 9:46am
JDH
Ah ok it makes sense now it's the height of the wings on the side of the seat base not the height of the actual seat base! My excuse is being a youngster I'm still learning Laughing thanks for the help! Thumbs Up
Post #476292 26th Nov 2015 10:12am
RRUK
You can see the difference here:
LOW SIDED SEAT BASE:
HIGH SIDED SEAT BASE:
 2016 D4 HSE
Post #476306 26th Nov 2015 11:03am
GypsySamuraiAnt
Australia 2015 Defender 110 Puma 2.2 SW Indus Silver
I'm not gonna lie, they're beautiful Mr. Green Thumbs Up Exclamation
Post #476316 26th Nov 2015 11:30am
YOLO110
Australia
Yes, neat looking seats! Thumbs Up
However, I am not going to lie as well... the significant side bolsters are designed for lateral support... e.g.: sports cars capable of 1g + cornering etc. I just don't see the need or application for this in a Defender... cornering g forces minimal and rough road lateral support being quite adequate with the OEM seats!
It's therefore all about the looks... and they do indeed look cool Cool YOLO... You Only Live Once...
Post #476321 26th Nov 2015 11:35am
RRUK
YOLO,
I get that, but most LR seats just sit ontop of, they don't hold you in at all, and the Defender bounces around a lot!
Some side support can make a big difference. 2016 D4 HSE
Post #476326 26th Nov 2015 12:02pm
