Home > Maintenance & Modifications > Front Runner Roofrack and Front External Roll Cage on a 90
DEF_Jam
Italy 2008 Defender 90 Puma 2.4 SW Stornoway Grey
To whom may did figure something out about the front legs/clamps of the roofrack,
Any picture would be appreciate Thumbs Up
The roofrack is the Slimline II with Tall Legs and the cage is the one on the picture below.
Post #474585 20th Nov 2015 3:39pm
Jimb1978
England 2002 Defender 110 Td5 Black LE Java Black
I did something similar with a Hannibal.
http://www.defender2.net/forum/topic20716-60.html
It's about half way down the page. 2002 110 td5
Post #474617 20th Nov 2015 5:31pm
DEF_Jam
But on the 1st picture looks like the front leg it's in the place with no problem.
That was what I was worried about.
Post #474635 20th Nov 2015 6:07pm
jasong4110
United Kingdom 2003 Defender 110 Td5 G4 LE Java Black
Albeit on a 110 I have a front runner roof rack and a front hoop, the legs fit to the gutter but the clamps don't fit onto the legs.
My solution was going to be to fabricate some new legs that clamped around the cage as the legs just bolt onto the underside of the rack, however 10 years and 80k plus miles of on and off road with things like a RTT on it, or loaded with other bits the rack has never shifted so I haven't bothered and the front legs remain unclamped.
Jason.
Post #474643 20th Nov 2015 6:50pm
Jimb1978
the leg doesn't quite rest on the gutter and is sprained inwards to the point I couldn't get the retaining nut on the bracket. The bulge the grub screw goes through was resting on the roll hoop.
ps. sorry the pictures are in reverse order. That was how the site uploaded them 2002 110 td5
Post #474647 20th Nov 2015 7:14pm
DEF_Jam
Jason.
Do you have a piicture of the job done?
Post #474660 20th Nov 2015 7:35pm
MT
Im in the same situation as jason. The front legs rest on the gutter nothing more, they are not secured as such. The other legs on the rackare as per designed. Again several thousand miles with RTT and never a problem on or off road. I'll brave the weather and upload a pic in a mo.
Post #474674 20th Nov 2015 8:09pm
Jimb1978
My concern was that the spreader plates had been cut and therefore not been doing their job. The inside of the gutter had some very big dents in its from the feet of the rack. I thought it best to distribute the weight to the roll hoop.
the previous owner had managed to manipulate the rack in such a way that the feet made contact with the gutter. I could not manage that again..must have been a fluke. 2002 110 td5
Post #474687 20th Nov 2015 9:05pm
DEF_Jam
Thank you.
I wish you had a P&P cage and a Front Ranner racks but if that's the situation right there it's more than okay.
You can easly design a clip that will secure the front legs in.
Do you have a picture of the look of the full car?
Post #474688 20th Nov 2015 9:05pm
MT
I'm pretty sure it is a P&P bar, it was the same situation with the genuine LR bar (also possibly P&P?) and a hanibal rack. The photos are on a 110 DC so it has 2 ladders as rear supports. As a result it means only 2 pairs of feet are secured to the gutter.
Post #474690 20th Nov 2015 9:14pm
DEF_Jam
Nice truck Thumbs Up
Post #474693 20th Nov 2015 9:25pm
MT
Thanks, its an ongoing project but it works hard.
Post #474702 20th Nov 2015 9:47pm
