Home > Maintenance & Modifications > Thermal Insulation and Adhesive
NormanD
England 2015 Defender 110 Puma 2.2 USW Santorini Black
What is the best thermal Insulation material and adhesive to insulate a Puma? NormanD WE191
2015 110 XS Utility
2014 VW Caravelle 180 Executive
Post #474278 19th Nov 2015 6:06pm
RRUK
It's very subjective and depends on what you are prepared to pay.
The main brands like dynamite and noise killer are expensive.
I buy the rolls of self adhesive thick closed sell aluminium backed material from Powerful Uk, they sell it on eBay. It's thick and I think cuts down panel resonance and noise, plus adds insulation. 6 rolls at £30 each will do an entire 90.
Buy a main brand and you'll pay £500. 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #474281 19th Nov 2015 6:24pm
NormanD
Thanks RRUK, I'm currently investigating Thermaliner - http://www.harrisonstrimsupplies.co.uk/5-x...3173-p.asp
This appears to be a Closed Cell Foam with adhesive backing, anybody used it? NormanD WE191
2015 110 XS Utility
Post #474288 19th Nov 2015 6:43pm
gilarion
Quote:
dynamite
Predictive text or spell checker strikes again Smile
Note: do not use dynamite to insulate, it does not work Wink For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #474289 19th Nov 2015 6:46pm
RRUK
Dynamat!!!!
Big Cry 2016 D4 HSE
Post #474290 19th Nov 2015 6:47pm
jimbob7
Thermal???I used typical household foil "blankets" on the doors/floor. I Noticed a difference,but when driving over the tops in high,high winds I could really feel the heat being sucked out of the door Shocked !!!So wear a good coat.
Honestly it was like a fan being turned on!!!! Pov.spec,ftw. 2006, 110,TD5.
Post #474299 19th Nov 2015 6:56pm
Romadog
Dynamat for sound deadening and closed Cell foam for insulation... Very Happy
CAMPING MAT - cheap and works well.
Need to be careful in some areas that you are not adding too much extra depth otherwisw carpets and / or rubber matting will not fit as well as it did previously.
Post #474300 19th Nov 2015 6:57pm
g-mack
Post #474318 19th Nov 2015 7:52pm
JAY BOY
Wales
I used this stuff and have no complaints really does make a difference and easy to install.
http://www.ebay.co.uk/itm/5m-x1m-THERMOLIN...4aefee2d4c
There are some more pics in my gallery of the install and finished article
Thumbs Up
Post #474320 19th Nov 2015 8:01pm
Radhaz stuff on eBay is a good thermal insulator, I used it under my battery box and in footwells for an arctic trip, we had overnight temperatures of -38c when stationary. To be honest the puma has a brilliant heater and does not need much except the rocker cover to airbox heater mod and that's only when you get to temps of less than -20c
Odyssey batteries are good to -50c
Post #474333 19th Nov 2015 8:40pm
Given the money some seem happy to splurge on their motors, I'm surprised this has been seen yet.
Post #474366 19th Nov 2015 9:51pm
dgardel
Italy
bpman wrote:
........ and does not need much except the rocker cover to airbox heater mod .....
could you give me more infos about this mod? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #474369 19th Nov 2015 9:58pm
Daniele
I will send you a PM
Bpman
Post #474415 19th Nov 2015 11:23pm
That's just a 2.4 engine issue isn't it?
Post #474463 20th Nov 2015 9:42am
qwert
2015 Defender 110 Puma 2.2 Heritage Edition SW Grasmere Green
bpman wrote:
..... the rocker cover to airbox heater mod ....
Can you please give more info?
Thanks.
Post #474486 20th Nov 2015 10:21am
