Home > Puma (Tdci) > 2.2 Engine code about oil? |
RF3777 Member Since: 10 Apr 2015 Location: Hong Kong Posts: 144 |
Last night playing the OBDII with my friends Defender 2.2 PUMA, we found the engine code as in the pic!
Would anyone explain what is this about? Click image to enlarge Thank You |
18th Nov 2015 6:45am |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 |
3 possibles ...
1, when the DPF regen cycle starts, diesel can find Its way into the engine oil [more so if regen cycle does not complete] After a period of time, the oil dilution reaches the max permissible level [7% if I recall] and the oil requires replacing. This usually brings the 'oil service' indicator on too .. 2, Its overdue an oil change [Again one would expect the 'oil service indicator to show - assuming it wasn't cancelled without changing oil] 3, Its an old logged code not been cleared When was oil last changed? does it do mainly short journeys? Guns and Landrovers .... anything else is irrelevant. |
18th Nov 2015 11:40am |
