Home > Maintenance & Modifications > Sun visors |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5085 |
Two machine screws for each visor, those screw into a captive bracket. You will notice on your front headlining, front windscreen edge; there will be four holes line these up with the four captives and the jobs a good en! For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
12th Nov 2015 11:33am |
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2017 |
Captive nuts held on the headlining or the body? 2016 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
12th Nov 2015 2:19pm |
Captive nuts attached to the roof you can clearly see the location on the pictures below.
Click image to enlarge Click image to enlarge For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
12th Nov 2015 3:08pm |
GypsySamuraiAnt Member Since: 31 Mar 2015 Location: Brisbane Posts: 131 |
Thanks I've been wondering this also!
Can you remove the head liner panels without removing all the plastic side trimming panels? |
12th Nov 2015 8:32pm |
Not really, as you risk the chance of damaging it. Removing the side trim is not that involved anyway.
I estimate that to remove the headlining and trim carefully takes about an hour with the right tools. Removal of the interior lights is much easier if you have the right sized socket for the nuts that hold the metal base plate behind the headlining as one of those nuts being so close to the plastic surround is a pain unless you have one of those little screwdriver sockets. Sometimes the fir tree fasteners will not come out no matter what you try and then you need a fine fret saw blade used without its holder to cut the head off, you can then once the headlining is removed tap out the stem of the fir tree with a punch or similar. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
12th Nov 2015 8:52pm |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6676 |
Hardest job removing the headlining is getting the rear view mirror bracket off !
At least one of the three rivnuts will spin |
13th Nov 2015 7:40am |
Matt,
Yes, been there, done that! 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
17th Nov 2015 1:59pm |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1784 |
Delayed thread resurrection! What size are the machine screws please Rob 1993 200tdi 90 hard-top 1998 300tdi 90 soft-top 2016 2.2 XS 90 hard-top |
7th Feb 2020 6:04pm |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 996 |
They're 6,3x19mm (14 x 3/4“) (AB614061L), but it's a self-tapping, not machine screw.
7th Feb 2020 7:37pm |
Thanks for the reply, but they are definitely not self tapping and go into captive nuts
7th Feb 2020 8:09pm |
Different model? Did I missunderstand what screws were meant?
Not these? https://www.lrworkshop.com/diagrams/land-r...sors_53618 |
7th Feb 2020 8:16pm |
No you didn't misunderstand, those are exactly the ones and as you can see they look like bolts, which they are, but described as self tapping
7th Feb 2020 8:20pm |
Ok... It's a while since I had a closer look but I'll check again.
May take a while though, so if someone else could shed a light on this? |
7th Feb 2020 8:30pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16934 |
Interesting that the drawing clearly shows Rivnuts (which would mean machine screws) but the description states Spiraloks which would mean self tappers. I suspect a change took place.
IIRC my 2007 TDCi uses M6 machine screws but I can't remember the length. |
7th Feb 2020 8:31pm |
