Home > In Car Electronics > Garmin Power lead
Simali
United Kingdom 2004 Defender 110 Td5 CSW Zambezi Silver
Garmin Power lead
I have a Nuvi and want tontry to tidy up the power lead so it doesnt hang all over the dash.
Does anyone make a proper lead that has bare ends to patch inTo a 12v feed ?
If not i guess an option is to fit a 2nd ciggy lighter tucked away somewhere and use that
All ideas welcome !,,,!
Post #471200 10th Nov 2015 8:18am
TR51
France 2014 Defender 110 Puma 2.2 SW Corris Grey
Maybe not quite the answer, but LR/Garmin made a custom. Lunt for the SVX's so maybe an owner / dealer could help with how it's mounted and maybe source the part for you...
Post #471206 10th Nov 2015 8:57am
Theater
Italy 2009 Defender 110 Puma 2.4 SW Galway Green
Re: Garmin Power lead
Land Rover Defender Personal Travel Assistant - LR008217
KIT - NAVIGATION SYSTEM (1) Part number: LR008217
BRACKET, MOUNTING (3) Part number: LR018662
FITTING INSTRUCTION
http://topix.landrover.jlrext.com/topix/co...oupId=1666
Wink Marco
Defender 110 "SW" SE Galway Green MY 2009
Ex Defender 90 "SW" S Santorini Black MY 2010
Post #471724 11th Nov 2015 8:34pm
Look here: http://www.ebay.co.uk/usr/edosupply?_trksid=p2047675.l2559
Make sure it's fused in-line. (I used 1A)
They are where I got mine hard wired and just comes up behind dash.
No need for more sockets or trailing cables
Post #471728 11th Nov 2015 8:46pm
tonyhedge
2014 Defender 90 Puma 2.2 SW Montalcino Red
Edotech also do a USB cable for charging a Garmin (in case you ever fit one of those neat dual USB outlets). Not a simple USB cable doesn't work, as it will convince your Garmin that the Defender is a source of map updates Sad That's not a dent, it's a rivet. That's not a dent, it's a rivet. That's not ... oh! That is a dent!
2014 90 XS SW
1997 Discovery 300TdiS (retired to stud)
1966 Series IIA 88" (now my son's)
2001 Astra - I need something to go and buy the parts when the others are off the road!
Post #471758 11th Nov 2015 10:01pm
I know what you mean on that one.
The one with the 90 degree plug on I have for a Nuvi 1300 that has worked perfectly for a long while now.
The plug in the socket as standard is a Censored in the way of 5th gear and dangerous too as you can catch your hand on the cable especially when going to indicate.
They are cheap too, and IIRC delivered from the US and tax exempt due to low value.
Post #471767 11th Nov 2015 10:16pm
ericvv
Mind, the Land Rover installation kit will provide an older type wiring, the one for the Nüvi 7xx series which today does not exist anymore. More recent Garmin series will most likely not accept that type of wiring anymore.
There is a seller on ebay who offers all or part of that type of Garmin wiring for the Defender. See below.
Eric
http://www.ebay.co.uk/itm/Land-Rover-Defen...xyhotSMHMs You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #471848 12th Nov 2015 8:14am
Simali
All sorted thanks for the ideas.
Post #472445 14th Nov 2015 1:26pm
