![]() | Home > Maintenance & Modifications > Cutting a slot in the fuse box cover |
Dave Bellis Member Since: 21 May 2014 Location: Shrewsbury Posts: 133 ![]() ![]() ![]() |
What is the best way to cut a neat slot in the plastic fuse box cover about 25x45mm to mount a blue tooth OBD adaptor?
Dave |
Hairysteve Member Since: 15 Jun 2015 Location: Surrey Posts: 692 ![]() ![]() ![]() |
Hi Dave,
Have you thought of something like this so you don't have to cut anything http://www.amazon.co.uk/gp/product/B00XHFM...ge_o05_s00 Cheers Steve |
Wild Card 90 Member Since: 03 Dec 2014 Location: Gerlingen Posts: 1060 ![]() ![]() ![]() |
Make a template by drawing the shape of the opening on paper. Cut out and glue it to the outside of the lid, checking the position is right. Drill a number of small holes adjacent to one another about 5mm inside the final opening. Cut between the hole with a carpet knife to remove the core. File out the rest with a round file.
Patience and a steady hand. Half an hours work. ...or buy the adapter HS has suggested - good idea. Stephen 1998 Tdi 90 SW, 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MTīs, Recaro CSīs, anorak, wellingtons |
Steve,
thanks for the reply, yes I've tried a low profile connector but it still fouls the cover. I came to the conclusion that a slot cut in the fuse box cover maybe best unless someone has a better idea... Dave |
Why not just pop the OBD port out of its holder
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
^^^^^exactly that^^^^^^^ 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered. |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3752 ![]() ![]() ![]() |
Then put a splitter cable in That how i run mine, and can then still access the OBD port
http://www.amazon.co.uk/Splitter-Extension...d+splitter California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
PK1 Member Since: 19 Oct 2012 Location: Gloucestershire Posts: 96 ![]() ![]() ![]() |
I did the following if it helps:-
1. Pop the original connector out 2. Connect it to a Y cable 3. The other end to your OBDII accessory and place up behind dash 4. Pop the remaining connector back in the original slot No need to cut a slot ![]() Range Rover Sport HSE |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5976 ![]() ![]() |
I just removed the small retaining surround for the plug, then plugged in my scangauge, then poked both through the hole. No cutting, not permanent, easy.
