Home > Puma (Tdci) > OBDII Adaptor/Splitter...
Venomator
Hi guys 'n gals... Thumbs Up
Would anyone happen to know if there is an OBDII adaptor/splitter thingy, like that below, which has the ability for at least one of the 'splits' to slot back into the original OBDII holder... Question
I have one such splitter already, but the replacement 'splits' are too big to slot back into the original port holder... Big Cry
 Rog... Mr. Green
The GREEN One...
MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color]
Post #470675 8th Nov 2015 3:02pm
K9F
The manufactured ones you can buy are absolute rubbish with the smallest diameter cable, in fact too small to work with. Considering there are only 7 cores to the OBD socket you are much better sourcing the piece-part spares and making exactly what you want if you have the tooling and technical acumen. I did by trawling the local scrap dealer for the piece-part spares. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #470692 8th Nov 2015 3:52pm
Venomator
Thanks Mal, but I am afraid I have neither... Rolling Eyes
I would happily use the existing OBD socket, but if you plug anything into it, in situ, the fuse panel cover will not close and it is a right Royal PITA to keep popping in and out... Shocked
The splitter I have did work with my Ultra Guage though and even permitted diagnostics from the alternate OBD spare socket, it just won't pop back in the OBD's home... Whistle
Mr. Green
 Rog... Mr. Green
The GREEN One...
Post #470700 8th Nov 2015 4:21pm
walfy
You can pop the original OBD port out of it's socket on the board. Plug in your Y splitter and then all is good. Cover goes back on and you can feed your loose tail up to where you need it.
Saves all the faffing around of making bits up. 110 D250 SE HT
110 USW SOLD
RRE HSE Dynamic Gone, wife killed it
VOLVO XC60 R Dynamic with some toys
Polaris RZR 900XP SOLD
Post #470715 8th Nov 2015 5:11pm
Venomator
Yarp, I did that in Mamba Walfy, but thanks for the suggestion... Thumbs Up
Just was looking for an alternative Y splitter that would fit the spare OBD plug back in its original home socket for the Keswick Special... Whistle
If it wasn't a brand new motor I might risk playing as Mal has suggested, but... Mr. Green
 Rog... Mr. Green
The GREEN One...
Post #470719 8th Nov 2015 5:22pm
walfy
It's the cheapest solution, ie free. Which is always good in my book. No new parts to buy or fail once they've been fitted. ANd you can reinstate in minutes and no one is the wiser Thumbs Up 110 D250 SE HT
110 USW SOLD
Post #470734 8th Nov 2015 6:03pm
Martin
Site Admin
None of the cheap Y splitters will be suitable. You will have to have a loom made up.
The original connector housing is available from LR under part number YPC107920 for a couple of quid.
Apart from the LR part above I have all the other parts needed to do what you need. Drop me a PM if you want the parts supplied or loom built Wink  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #470815 8th Nov 2015 9:38pm
Venomator
Wowsas, that is awfully decent of you Martin... Bow down
You (will) have a PM... Whistle
Thank you... Mr. Green
 Rog... Mr. Green
The GREEN One...
Post #470830 8th Nov 2015 10:11pm
