![]() | Home > In Car Electronics > Correct way to splice wire |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6722 ![]() ![]() ![]() |
Scotchlock - no way. They are unreliable, and allow moisture into the core of the cable
![]() Number 1 only if you don't mind it coming undone ![]() Number 1 plus a dab of solder is not bad. Personally I would cut and re-join with solder and heatshrink covering up. LR use these extensively in accessory fitting and I keep meaning to get some to try: http://www.polevolt.co.uk/acatalog/Jointing_Terminals.html (top 2 products) Cut the wire, strip the ends, insert all three and heat with a hot air gun. ![]() ![]() |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2415 ![]() ![]() ![]() |
Those are good! Well found Martin.
Sphere Member Since: 26 Apr 2013 Location: Midlands Posts: 725 ![]() ![]() ![]() |
Look super think I may be ordering some of them!
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
I've never had much success with the heat shrink solder things I prefer a dab of solder then heat shrink over it.
tonyhedge Member Since: 07 Jul 2015 Location: Worcestershire Posts: 101 ![]() ![]() |
Handy - thanks Martin. Reminds me of "Sleeves, self-soldering". Shows my age - anyone else remember them?
The other thing worth investing in is the rubberised cloth tape used by LR in all their looms. With a little effort you can add extra accessories to the loom that are alomst indistinguishable from original wiring. That's not a dent, it's a rivet. That's not a dent, it's a rivet. That's not ... oh! That is a dent! 2014 90 XS SW 1997 Discovery 300TdiS (retired to stud) 1966 Series IIA 88" (now my son's) 2001 Astra - I need something to go and buy the parts when the others are off the road! |
TESA harness tape
Cut and paste from an identical thread. Crimps are noy unlike Martin's but you need the tool as well.
If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
You could send me some
PM me your address and I'll dig out a few. If you go through life with your head in the sand....all people will see is an ar5e!!
Thanks
ericvv Member Since: 02 Jun 2011 Location: Near the Jet d'Eau Posts: 5817 ![]() ![]() ![]() |
Why are the red in both depicted cases for 0.5-1.5mm cable and both of the blue for 1.5-2.5mm cable, with no other size options available? Does blue by definition have to be bigger diameter cable? Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Mike_B Member Since: 23 Jan 2011 Location: Moray Posts: 550 ![]() ![]() ![]() |
I believe the crimps are colour coded by size, red, then blue, then yello. The colour is not there to differentiate between live and Earth. Poor choice of colour, but that's life! Use the cable colours to indicate the purpose of the wire! Plus, if you crimp, you could always heat shrink over the crimped connection like I do if I'm using a terminal, that way it can't be seen. Failing that, if your joining cable as opposed to terminating cable, solder them neatly and heat shrink.
JAY BOY Member Since: 04 May 2010 Location: Not here Posts: 1706 ![]() ![]() |
ericvv
red crimps are up to 1.5 mm cable Blue crimps are from 1.5 mm-2.5 mm Yellow are 4mm - 6mm That is the largest insulated crimps you can buy. After that they come in Non insulated which you would slide heat shrink over and insulate that way. ![]() |
Red, blue, and yellow (Who is afraid of red, yellow and blue?
![]() ![]() Click image to enlarge Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
