![]() | Home > Technical > TD5 defender headlight failure - HELP PLEASE |
Kev stephenson Member Since: 27 Feb 2012 Location: Huddersfield Posts: 56 ![]() ![]() ![]() |
It was the internals of the indicator stalk that melted not the light switch (i.e. the shorter stalk) 2005 110 TD5 XS running Alive Stage 1 and a bit and other toys 1996 130 300TDi chip truck for tree surgery business |
It appears there is some confusion here, to me the light switch (as you called it) would be the shorter stalk used to turn the lights on!! The problem I had was with the internals on the indicator stalk which operate the low beam/full beam switch. Feel free to give yourself a pat on the back if you so wish 2005 110 TD5 XS running Alive Stage 1 and a bit and other toys 1996 130 300TDi chip truck for tree surgery business |
Off topic but good to see another huddersfieldien on here
Very problably the light switch (short stalk), I would advise to fit relays in addition to a new switch, otherwise it will happen again sooner or later if you only replace the switch.
See http://www.defender2.net/forum/topic16451-7.html Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
tasr12 Member Since: 09 Jun 2013 Location: Dorset Posts: 228 ![]() ![]() ![]() |
Thanks - read up on the relays earlier.
New switch it is then....wind deflectors will have to wait! 2002 110 CSW TD5, Zambezi Silver 1995 110 CSW 300TDi - SOLD |
On the above - can anyone recommend a made up loom and what am I going to be looking at paying - £30? I've seen a Swedish one in other posts?
May take the hit and get the loom done as well, not ideal but I've got some miles in the dark next weekend so probably a good idea! 2002 110 CSW TD5, Zambezi Silver 1995 110 CSW 300TDi - SOLD |
davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888 ![]() ![]() ![]() |
Assuming that you were using the normal high beam and not the "flash" function then it's not the short light switch it's the indicator/light switch. The main lighting switch provides power to the indicator/headlight switch and that directs it to dipped or main beam. If the short switch was at fault then normal high beam would not work either. http://www.yorkshireoffroadclub.net/ |
Dave,
Great answer thanks, from reading other threads on this I couldn't be sure. Cheers, Tom. 2002 110 CSW TD5, Zambezi Silver 1995 110 CSW 300TDi - SOLD |
Can anyone give me a steer on what a loom/relay and switch change will cost at an Indy? Trying to be proactive in advance of them opening as time is tight with work to get this sorted.
Cheers. 2002 110 CSW TD5, Zambezi Silver 1995 110 CSW 300TDi - SOLD |
To fit a relay would be £20 of bits and maybe 2 hours. I think it took me about 3 hours including changing the headlights to Crystals, dealing with light guards and me not knowing what I was doing.
Thanks. 2002 110 CSW TD5, Zambezi Silver
You can buy a prewired relais and loom for approx. € 40. I installed it myself, took about an hour.
Easy mod, no wire cutting or soldering, and you can go back to original any time. ![]() Click image to enlarge https://shop.landreiziger.nl/lichtversterk...elais.html Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2378 ![]() ![]() ![]() |
I'll second the above kit, it's nice quality and fits nicely. Buying from them is as easy as buying from a home retailer.
Thanks - will look at it.
More help needed though - just changed both the switches (small stalk and the indicator/dip/horn) neither has improved the situation! I still get sidelights and full beam but no dipped?? Any other advice before I re-assemble? Thanks. 2002 110 CSW TD5, Zambezi Silver 1995 110 CSW 300TDi - SOLD |
