![]() | Home > Puma (Tdci) > Defender PUMA = unstopable. Dune driving suggestion. |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
never really done any serious driving on sand so can't comment on the above but one question.
how does sand affect the swivells and the seals, is it bad for them, all that grit etc same with UJs i'd image? cheers BM52 |
it does affect them if you do enough driving in sand. the biggest issue is the bushes on the radius arms. sand gets inside and can really ![]() |
never thought about the radius arm bushes. the solution sounds so simple but, presumably, effective. wonder why LR never modified the bushes to minimise the impact of this issue. BM52 |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3711 ![]() ![]() ![]() |
Under the seat in a Puma well it was in mine. 130's have feeling's as well you know ![]() |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8451 ![]() ![]() ![]() |
under the steering column in my Puma for a fuse although the actual unit is under the drivers seat and can be disabled there.
If lowering pressures for a bigger footprint for greater traction is a myth then who ever designed beadlocks has a hell of a myth going there and i have fallen for it. So much so in fact that running beadlocks and 8psi was like having the axle locker engaged for the additional traction it gave. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
AlanH Member Since: 15 Mar 2010 Location: WA Posts: 242 ![]() ![]() |
Lowering pressures is certainly standard procedure in Oz and I've had mine down to about 10psi to get up long dunes of soft sand.
Trying to get off beaches with hard tyres is sometimes impossible and only serves to cut tracks up and cause deep holes making it worse for those that follow you. I don't think what SFs do is relevant, they don't pay for their own vehicles and it doesn't matter if they thrash the hell out of them. As far as I'm concerned it takes a lot strain off the running gear as well. Easier on the vehicle will make it last longer. Alan. |
4wheeler Member Since: 13 Apr 2010 Location: Melbourne Posts: 87 ![]() ![]() ![]() |
Agree 100% with Alan. First thing I do is drop pressures in off road situations, particularly sand. I start at 24 PSI for sand and drop from there depending upon how dry and how fine the sand is. Standard off road driving I drop to 28 PSI and lower from there for rock etc. I have never punctured and never dropped a bead. I just adjust my driving. No high speed and no sharp turns to pull the bead off the rim. Obviously pressures depend on load carried to a degree. I look at the footprint of the tyre. As you drop pressures the tyre wall tends to bag out a little but more importantly the length of the tyre footprint extends as tyre pressure drops. This aids in floatation in sand and supports the vehicle. Much kinder on the drive system. I once had my Ford utility bogged to the diffs in soft sand on a beach with sea water lapping at the front wheels. Numerous attemps to drive out failed at 24 PSI so I bit the bullet and dropped them to 10 PSI. Drove straight out to much relief. Have never been stuck anywhere since. |
Vixen Member Since: 17 Mar 2010 Location: NSW, Orstraya Posts: 97 ![]() ![]() |
I have a friend that NEVER drops his tyre pressures in sand. He never has a problem. Except that everyone is always telling him he is doing it wrong
![]() ![]() What I have noticed with lower pressures is a much better and more comfortable ride if nothing else ![]() |
An old nomad once told me that to get the perfect tyre pressure for driving in sand is to do this.
Park on a level area in the sand you are about to venture into. Deflate all the tyres. Place a handful of sand on the outer sidewall of each of the tyres. Re inflate the tyres keeping an eye on the handful of sand you placed on the sidewall, as the tyre inflates the sand will slide off the sidewall when this happens stop inflating. You now have the perfect pressure for your tyre type, vehicle weight and sand conditions. Dont tell anyone though as this is one of the best kept desert driving secrets ![]() ![]() |
Ninetenths Member Since: 26 Mar 2009 Location: Sarf Lundun Posts: 161 ![]() ![]() |
![]() Equally Pimped Black Pick up Truck Rollin deep |
Contact patches on a tyre at road pressures are tiny, you can increase them considerably by reducing tyre pressure and this dosent necessarily have to be so much that there is a risk of losing a bead. Of course vehicle weight/tyres/speed/sand temperature and type are also significant. Special forces et al use sand tyres and tend to have stripped down vehicles in any case. Pimped black '07 Puma
Neither of those points are correct. |
Pink Panther ![]() Equally Pimped Black Pick up Truck Rollin deep |
