Home > Technical > Difflock light!!
dave18
United Kingdom 1984 Defender 110 300 Tdi CSW Portofino Red
Difflock light!!
Right peeps. My Diff lock light has never worked and the linkage was a bit suspicious. So whilst I had the seat box out I had a look. The linkage is just worn in places and it turns out Tue difflock switch wasn't connected.
So put a multimeter on the switch and got continuity when in difflock so wired it back up ( old Blue Black cable was tucked away). Anyways the light still doesn't work. So checked and getting full Volts at the switch and used a different earth still no luck. Swapped Tue bulb for a none good one and still no luck.
Earthed the Blue Black cable still no luck. Did a continuity check from dash connector to the switch end all is good.
So what's the issue. I have good voltage and a good earth along with a good bulb but still no light!!
Post #468583 2nd Nov 2015 12:31pm
Martin
Site Admin
The difflock switch creates a ground path for the lamp and from what you've said it sounds like everything is OK Confused
With the switch connected up are you getting continuity to ground at the blue/black at the dash connector when difflock is engaged?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #468586 2nd Nov 2015 1:12pm
dave18
Cheers for the reply. Yep getting continuity everywhere, that is what's annoying me getting power where should as wel!
Post #468622 2nd Nov 2015 2:53pm
dave18
Tried using a couple of different earth locations ( currently earthed to the Transfer Box) but still no luck.
Checked the copper strip on the dash lights and thats all good and working. Rolling Eyes Rolling Eyes Confused Confused
Post #468969 3rd Nov 2015 10:56am
Freypal
United Kingdom 1992 Defender 90 200 Tdi HT Portofino Red
Not sure if this is covered by your post above so apologies if it's stating the obvious, but is the switch definitely adjusted properly? You can wind them in and out until the plunger of the switch makes contact with the lever at it's engaged position.
Post #469832 5th Nov 2015 7:14pm
dave18
Freypal, Cheers for the reply, Im assuming it is adjusted correct as in normal mode the switch has no continuity but when in difflock I get continuity. Also doesnt explain why the light doesnt come on when I earth the cable !!! Cheers thou
Post #469860 5th Nov 2015 8:57pm
dorsetsmith
Is there continuity to and from the light board plug on the dashboard down to the difflock switch Question
Post #469871 5th Nov 2015 9:30pm
Freypal
Odd, on the wiring diagram power is sent to the switch via the dash so if you're getting 12v at the plug on the blue wire it should work. Can't see how its anything other than the earth from the switch to ground.
What happens if you bypass the switch and try earthling the blue wire directly with ignition on?
Post #469876 5th Nov 2015 9:42pm
dave18
Nothing happens. I've even jumped the from the back of the dash connector to a good earth and tried two bulbs which are working in other warning lights. Bloody annoying
Post #469928 6th Nov 2015 12:07am
dorsetsmith
is possible cct track is open cct on the light board Question
Post #469933 6th Nov 2015 12:23am
dave18
Doubt it as get continuity from the 12v feed on the light cluster all the way to the switch earth when I engage diff lock !!
Post #469938 6th Nov 2015 1:03am
Freypal
All it can logically be is some kind of short behind the cluster, bypassing the bulb. Is there anything behind that could be doing that?
Post #469971 6th Nov 2015 9:17am
dave18
Not that I can see but will check all of them again. But surly running an earth from the blue wires on the dash connector would illuminate the bulbs.
Post #470021 6th Nov 2015 11:34am
dave18
Well good ole Landy, Was in the 110 this evening as been doing work on it and had the engine running, Got a power lead caught round the diff lock lever and it got pulled into Diff Lock. And as if by magic the Difflock light came on!!!!! Played with it a couple times and all is well !! Bloody Landy s Laughing Laughing Rolling Eyes Rolling Eyes
Post #470557 8th Nov 2015 12:06am
