Home > Maintenance & Modifications > Warn winch Bumper Suggestion
Page 2 of 2 <12
mcma1
my old goodwinch intall was a lot more work, we had to move the radiator and aircon back to fit the Alive intercooler in... and then cut and plastic weld the SVX grille. I just didnt want to go through this again, plus i find with the soft A bar the winch does not appear to stand out as much..
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #468575 2nd Nov 2015 11:59am
Skeggy 90
England 2011 Defender 130 Puma 2.4 SW Bali Blue
Warn 10S with Flatdog bumper, just need to work out where to pur the number plate.
 90 300 TDI SW (sold)
130 TD5 Utility (Foley SV) (sold)
110 TD5 Hardtop (sold)
110 TDCI Utility (sold)
1st Edition Range Rover Sport Supercharged
Velar P380 HSE
Discovery 1 V8 auto
Puma 130 Double Cab (sold)
R35 GTR
Defender 110 300 TDI CSW (sold)
2010 110 XS Utility
Post #468654 2nd Nov 2015 4:59pm
West Yorkshire Lofty
Scotland 2015 Defender 90 Puma 2.2 HT Fuji White
Flatdog order
The deed is done winch, bumper, cover and flatlink ordered!
Due to be installed next Thursday.
Photos to follow Very Happy
Cheers West Yorkshire Lofty 2015 90 Keeper
2005 R300 Keeper
2019 XC40 Shopping Trolley
2008 110 XS Utility (Friday Build) Gone!
Post #470447 7th Nov 2015 7:25pm
mcma1
Good stuff. Did you go synthetic? Are they putting in a isolator switch.? Etc.... Andy
2014 Corris 110 SW
LS3 V8 build...
Post #470450 7th Nov 2015 7:34pm
Install Details
Yes and yes.
Had to go synthetic, not a fan of wire rope. Tirfors do have their uses but do expose the problems with wire rope!
Isolator will be installed, probably on the passenger seat box. As this is where the two optima batteries are housed with the split charge system.
2005 R300 Keeper
Post #470589 8th Nov 2015 7:11am
Install Complete
Well Gents,
Winch installed Finishing Touch Autos did a excellent job as usual!
Installed cut off switch on passenger side seat box.
Mantec reg plate holder hides winch, which can only be a good thing these days.
 2015 90 Keeper
2005 R300 Keeper
Post #472802 15th Nov 2015 8:42pm
WhiskyJackR
Looks great. Really has that standard look with the bumper caps.
Only thing missing is the optional rope protector plate for UV protection. It just clips in. Either solid or with slats. Any farther South and I'll need to trade the Defender in for a Landing Craft Smile
Post #472828 15th Nov 2015 9:47pm
Solid Protector
Your right ordered the solid protector but it would fit!
Installed the synthetic rope as per Warn instructions so will try again.
It's a shame to hide your kit behind protectors and reg plates, but this is the world we live in!
Cheers WYL 2015 90 Keeper
2005 R300 Keeper
Post #472892 15th Nov 2015 11:08pm
WhiskyJackR
The protector plate is a little tricky to get onto the bottom clips. I used a screwdriver with a cloth over it and gently pushed it into place. took a couple of minutes or so of fiddling and cursing as the access is limited. Don't be afraid of prising a little against the bumper.
I think after a few on and off's it will click in much easier, the plastic will wear in. Looks fab in place, mine has the slats which is funny as I ordered solid Smile
How was your remote range on the 10S? My first controller was good for about two feet. Some of the controllers have a recall on them. The replacement Warn arranged to be sent from the US is great and I can walk a long way from the truck and control the winch now. Any farther South and I'll need to trade the Defender in for a Landing Craft Smile
Post #472902 15th Nov 2015 11:25pm
WhiskyJackR
I'm guessing you pre-loaded the rope when winding on? Any farther South and I'll need to trade the Defender in for a Landing Craft Smile
Post #472931 16th Nov 2015 12:29am
New install
Yes pre loaded the rope yesterday. Used the weight of the motor up a slight incline. Didn't have enough room for a single pull so used a pulley for the first half. Me thinks I may need to use a steeper hill and single pull to get enough tension!
As for the remote it was working fine from about 10m away?
2005 R300 Keeper
Post #473194 16th Nov 2015 8:51pm
Page 2 of 2 <12
