|  | Home > Puma (Tdci) > Defender PUMA = unstopable. Dune driving suggestion. |
| Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2687      |
 Andrea, welcome   AFAIK, the Puma does not have DSC, only ABS+TC
 Get a Gmail account, which gives you access to PicasaWeb. Upload your images there and link them in your posts using the IMG tag. | ||
|  30th Nov 2010 10:58am |
| dgardel Member Since: 30 Nov 2008 Location: Veneto (Heart & Head) Posts: 3586    | Andrea,
 WE ARE WAITING YOUR PHOTOS!!!!!!!!! I'm not stay on my skin for that!!!!!!!!!!!!!!!!!!!      Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition   IID Pro MV License | ||
|  30th Nov 2010 11:08am |
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6736      |
 Or host them here (no new accounts needed) http://www.defender2.net/forum/topic123.html http://www.defender2.net/forum/topic124.html  1988 90 Td5 NAS soft top  2015 D90 XS SW | ||
|  30th Nov 2010 11:57am |
 Yes, but no categorisation/geotagging  | ||
|  30th Nov 2010 12:02pm |
| Andrea Member Since: 02 Sep 2010 Location: South Africa Posts: 30      |
 Naks, hi,
 Sorry my error, it desables the ABS, so the system does not interupt your momentum by applying breaks at any stage!! Works a charm! I will put pics up as soon as i get them off the sticks!! | ||
|  30th Nov 2010 12:24pm |
 Ok, makes sense. But I've never had to disable TC when driving in sand. As long as your tyre pressure is at 1.0 bar (or lower) and you choose the correct gear and maintain momentum, TC very rarely kicks in. See the following pics - TC did not even light up once when I climbed these dunes, and these were the small ones I climbed      | ||
|  30th Nov 2010 12:38pm |
 look tire pressures play a big part of the whole thing, I went to 0.9 bar, didnt want to go lower as we where towing the big trailers!! The part that i found that it helped a HUGE amount is when pulling off, the TC would come on instead of letting the cars tires gain momentum!! Disabling it gave the car a much easier pull off!!!
 That looks like awesome fun, Is that the ATLANTIS dunes? I must say the Range Rover classic was better than all the cars in the sand, even better than the cruisers with both diffs locked!!! The dunes in the namib are relentless, the mintue you think you have a bit of an advantage you find yourself up to the axles!! Very fun!  | ||
|  30th Nov 2010 12:56pm |
 Yep, bucketloads of fun  | ||
|  30th Nov 2010 2:58pm |
| BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253    | i dont agree about tyre pressures. you drop your pressure and you run a serious risk of popping the bead(s). I;ve never had any problem in sand keeping the pressures at normal.  Put it this way, I'd rather get stuck than have to put a tyre back on. | ||
|  30th Nov 2010 4:58pm |
| TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3752      | On a few trips to North Africa, we also found, disabling the ABS/Tracs, was a big advantage in soft sand,
 We had one hill, that the Puma would not climb,, High/low box, 2/3/4 gear, dropping the tyres pressures even further, all did not work,, but removing the ABS fuse, and she sailed up no problem,, The traction control,. was robbing the car of all its power California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK | ||
|  30th Nov 2010 8:50pm |
| AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3711      |
 You cant have ever driven in soft sand then    I have taken cars into dunes running standard pressures and the vehicle will loose momentum and stop. So drop the pressure to 13psi ish get back in and away to go. Oh I have never poped a bead
 Totally agree  take the fuse out is the way forward. 130's have feeling's as well you know  | ||
|  30th Nov 2010 9:11pm |
 Braver than me Andrew,, 15 is about as low as i go on a 255/85  and No, I have never popped one either,, The beadlocks on the challenge truck go down to about 6psi,  California F1, 75th 110 "Kermit",  50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK | ||
|  30th Nov 2010 9:22pm |
| Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686  |
 As Andrew says  , I launch and retrieve my boat on soft sand and have  never had a problem once I lowered pressures to about 13psi. This includes getting traction whilst towing the boat & trailer up steep beach inclines and dunes, even with GG TR's fitted. Also the landy doesnt sink as much while sitting in the water waiting on me getting the boat back on the trailer  | ||
|  30th Nov 2010 9:27pm |
| AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3711      | 13 in the morning increases to about 15 when the temperature gets up    well so I am told  never actually checked but never had an issue so I believe it    130's have feeling's as well you know  | ||
|  30th Nov 2010 9:30pm |
| Posting Rules
