![]() | Home > Technical > Reverse light |
Have you seen this thread?
http://www.defender2.net/forum/topic32834....p;start=15 |
TooTall Member Since: 10 Jul 2012 Location: Fens Posts: 504 ![]() ![]() ![]() |
Double Labcraft scene light means problem solved; in fact I probably now have more light going backwards, than most people have going forwards
![]() Go into your garage & put stuff into rows." |
BossHog Member Since: 28 Jun 2013 Location: Fylde Coast Posts: 185 ![]() ![]() |
Thanks for the link, I wasn't aware of the scene light, think that's the way to go.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17735 ![]() ![]() ![]() |
You might want to make sure that the reversing light switch is properly screwed into the gearbox. It's not unknown for it to be loose, in which case the light will be intermittent.
BW thanks for that I will check the switch, now I know where to look!
