Home > Puma (Tdci) > Washer nozzles!
szracer
England 2010 Defender 110 Puma 2.4 USW Stornoway Grey
Washer nozzles!
Bloody things!
Guess they're the first bit to fall off my new 110...probably not the last. Shocked
One on the front fell off this morning, and pinged down the road. Checked the one on the rear and it came away in my hand.
My LR dealers is on my way to work, and strangely enough, they had 'dozens' of the the things in stock...! I'm thinking they are a frequently lost bit.
Got the new bit but can't work out how to a) remove the outer nozzle bit from the rest (comes with the rest of the part as well) and b) keep it retained on the bit sticking out below the windscreen.
Any tips?
2010 110 XS USW (the slow one)
1960 Alfa Romeo Giulietta SZ (the fast one)
2005 Ducati ST3
1954 Sunbeam S8
Post #46306 25th Nov 2010 1:32pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Put it in hot water and pull, then super glue it back on, make sure you don't put too much glue on or it will block it up and won't work Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #46314 25th Nov 2010 3:25pm
szracer
Cheers!
Will give it a go.
2005 Ducati ST3
1954 Sunbeam S8
Post #46319 25th Nov 2010 4:16pm
entreq (site sponsor) have a project to re-design these ... another top seller if they make it !
Post #46333 25th Nov 2010 7:20pm
Grockle
use screen wash addative,that will stop the water freezing in the lines and pushing the nozzles off 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #46347 25th Nov 2010 9:12pm
dgardel
Italy
but it is for headlamps cleaning, not for windscreen..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #46364 26th Nov 2010 8:29am
mse
What he said...no problem Thumbs Up Mike
Post #46401 26th Nov 2010 5:02pm
Lorryman100
SWRA WINDSCREEN WIPER CLEANER
DESCRIPTION
Our windscreen wiper cleaner ought to have been ready long since, but there were a number of minor problems.
First, the standard water tank for the windscreen jet nozzles is far too small for the entire SWRA system to work satisfactorily. Then there were repeated malfunctions of the hold pressure value until we finally found the right manufacturer.
To crown it all, the high-pressure pumps had difficulty in taking up water from the (refilled) reservoir because they are always designed for fitting directly in the water container and not for external use.
We are now working on an additional tank for the SWRA with a volume of just under 10 litres of water because it is only then that a cleaner with high water consumption really makes sense.
Post #46403 26th Nov 2010 5:49pm
mse
Rolling with laughter Rolling with laughter Mike
Post #46404 26th Nov 2010 5:50pm
spudfan
Ireland
My washer nozzle on the rear of the tdi got broken some years ago. As a temporary repair I used a piece of break line bent to shape, with the exit end flattened with a pliers. I just stuck it into the protruding plastic pipe over the rear window. This temporary repair is still in place. Works really well. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #46411 26th Nov 2010 6:24pm
szracer
OK, so following suggestions on here, I successfully separated washer nozzle from the part it fits to, then after heating it up in hot water and giving it a sharp tap with a hammer, got it to click on to the bit sticking out of the scuttle.
Now, being REALLY stupid, I can't seem to adjust the nozzle direction. They both shoot into space!
Been trying with a pin, but to no avail. Is there a trick to it?
2005 Ducati ST3
1954 Sunbeam S8
Post #46722 30th Nov 2010 12:30pm
RED-DOT
I use a needle but i guarantee it will pop off in the minus weather we are having.... 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #46724 30th Nov 2010 12:32pm
mse
It shouldnt pop off
Trick - more antifreeze! Thumbs Up
Dry jet arm
Dab of superglue if it keeps coming off (dab as you want to remove it again!!)
Heat and refit Mike
Post #46765 30th Nov 2010 4:53pm
RED-DOT
Mine did when jets froze and water pressure launched the unit skywards... 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #46767 30th Nov 2010 5:01pm
mse
-10 here on saturday night/sunday and when we left the house at 9 it didnt Mike
Post #46768 30th Nov 2010 5:03pm
