Home > Wheels & Tyres > Continental cross contact noisy?
chipmunk
2012 Defender 90 Puma 2.2 HT Oslo Blue
Has anyone else found that these original fitment tyres howl? Was beginning to think it was one of the diffs or a wheel bearing but with only 16k on the clock this is unlikely..............or is it??!!
Post #467563 29th Oct 2015 4:01pm
T1G UP
yep and they just get worse.
Post #467576 29th Oct 2015 4:59pm
discomog
My Disco 3 had a new rear diff at 1500 miles because it whined- so don't rule anything out. Must admit hadn't noticed my 90's OEM tyres howling.
Post #467582 29th Oct 2015 5:14pm
alby
United Kingdom 2015 Defender 90 Puma 2.2 SW Santorini Black
My defender originally had steel wheels and latitude cross tyres, they were in general quiet, however i found they used to howl a bits of road with smooth, recently relaid tarmac (a rare thing round these parts!!) they were run at be book pressures for a light load.
Not as bad as the howl from a set of goodyear xtragrips, but a noticeable howl.
Have now fitted boosts with conti cross contacts (again set to the book pressure for light load) have found they don't do it.
Post #467591 29th Oct 2015 5:35pm
Cake
I have these tyres and find them extremely quiet - one of the points of keeping them on there.
Check your tyre pressures as they might have something to do with it.
Also check your alignment - one thing I have seen is opposite wear on tyres so run your hands on the tread from the front of the car to back, if you find it catches then that can be a cause - swap them round and after a few 100 it should quieten down.
Post #467616 29th Oct 2015 6:54pm
Cake
Also, very unlikely but remove anything stuck in the tread.
I have had a few stones in mine and drives me crazy on smooth roads, I have to always pick them all out!
Post #467618 29th Oct 2015 7:04pm
chipmunk
It does get worse if I'm carrying a heavy load and varies with different road surfaces which made me think it is the tyres. I've had a 90, a Def TD5 and a 300 Tdi Disco with BFG ATs and GG ATs, all 265/75 and all were good. It's not really intrusive but annoyingly noticeable.
Thinking of changing to 265/75 AT2 so if anyone in the market for 5 Contis with 16k miles, spare unused...........let me know.
Post #467681 29th Oct 2015 9:50pm
Natlas
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Aintree Green
I have a Defender which came with these tyres as new. Nice and quiet until at about 15K miles I thought I'd move them around to even out the wear and included the new spare in the juggling act. - The result was significantly increased road noise, presumably because of the strange wear pattern that tends to develop on chunky 4 X 4 tyres, you could see the even but lumpy wear pattern poking through the canvas spare wheel cover.
So my guess is that unless all 4 of your tyres have been worn evenly from new and NOT swapped about, you will get noise from them.
It appears to be best to fit 4 new ones together, never move them around, (they last long enough anyway) and enjoy the relative but not perfect silence. Smile
Cheers,
John. 2.2 90 XS
88" Series One
Old Norton Smile
Minerva
Post #467683 29th Oct 2015 10:02pm
dave18
United Kingdom 1984 Defender 110 300 Tdi CSW Portofino Red
Got 235/85/16 had them for a couple thousand miles and cant say ive noticed any road noise.
Post #467690 29th Oct 2015 10:29pm
chipmunk
I have never bothered changing tyres around. As said they last long. Just bought the car so don't know whether they've been rotated ( no wise cracks Very Happy ). Wouldn't have thought so at !6k miles.
Post #467700 29th Oct 2015 10:55pm
SteveK
United Kingdom 2002 Defender 110 Td5 HT Rimini Red
I don't find them noisy except at low speeds on Tarmac!
Post #467976 30th Oct 2015 11:29pm
nidge n
Noise wise, 40,000 miles in and I've Not had an issue with mine. I have noticed reduced stability even though there is quite a bit of tread left.
Post #471106 9th Nov 2015 9:31pm
Pickles
In view of the relatively "large" tread relative to a road tyre, I reckon they're very good. 31,000ks on ours, I'd buy 'em again.
Pickles.
Post #471110 9th Nov 2015 9:38pm
WhiskyJackR
For the type of tyres they are pretty much what I expected in terms of noise. They don't bother me although my friend drove it and he complained they were much noisier than the tyres on his Range Rover Westminster!!! I didn't have a response Shocked
I've covered 7000 miles now and the wheels have not been moved around the vehicle. Any farther South and I'll need to trade the Defender in for a Landing Craft Smile
Post #471150 9th Nov 2015 11:22pm
PeeWee
England 2010 Defender 110 Puma 2.4 XS CSW Rimini Red
Noisy? when the Cross C's are fitted my 110 sounds as if it has a collection of bad wheel bearings.
The only reason I know that it is not the bearings is that the BFGs that I use in winter (I work in and around ski resorts) are so much quieter. Cab someone suggest a a "summer" tyre that is as quiet running as the BFGs?
PeeWee
Post #616650 13th Apr 2017 9:02pm
