![]() | Home > Puma (Tdci) > Puma engine fault |
https://www.defender2.net/gallery/albums/u...VCV%20.pdf If you go through life with your head in the sand....all people will see is an ar5e!!
Crofter Member Since: 19 Feb 2015 Location: Peterhead Posts: 169 ![]() ![]() ![]() |
Thanks.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17950 ![]() ![]() ![]() |
it is a simple job to change, and takes about 10 minutes to fit the new valve. Don't forget the all-important last step, however, "Using the Land Rover approved diagnostic system carry out the pump learn procedure found in the set-up and configuration section."
You must carry out a pump "relearn" cycle using a diagnostic tool to recalibrate the pump, and this muct be done with a hot engine. |
AlanH Member Since: 15 Mar 2010 Location: WA Posts: 242 ![]() ![]() |
I think I must be thinking of a different valve blackwolf, as the one I'm talking about is behind the fuel lines and the inlet pipe and no way can I get my hand in there to change it.
And now the independent I was going to get to change the thing (a 1 hour job he reckons) isn't returning calls or answering emails..... back to the stealer it is then. ![]() Hopefully (some hopes) this will be the very last time I ever go into a LR dealership for anything. AlanH. |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5999 ![]() ![]() |
It's easy to change the VCV, but does take some fiddly tool work to be able to get access to it. I recall have to use UJ's and sticky tape to get to the back bolt. But it can be done.
Andy |
