![]() | Home > Puma (Tdci) > clunking sound when pulling up |
Andrea Member Since: 02 Sep 2010 Location: South Africa Posts: 30 ![]() ![]() ![]() |
Dasha, Best thing to do in this case is take it to your dealership and let them put the "earmuffs" on and let the warrenty work its wonders. Mine did a similar thing, turned out to be something small with the rear diff. They replaced the unit with a new one-no problems.
dasha Member Since: 15 Aug 2007 Location: newcastle Posts: 7 ![]() ![]() ![]() |
Thanks Andrea went that route, bloody thing didn;t do it, well not as loud or long as normal so the mechanic couldn;t pin point it series 3 swb gone . o5 defender gone
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2474 ![]() ![]() ![]() |
Mine that sympthom, but in the back. I was one bush from the A-frame. Did you check the UJs? Puma 110" SW
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 ![]() ![]() ![]() |
Mine did that - especially when warmed up.
The dealer adjusted the parking brake and that solved it.... ... for a while. Started doing it again now. I'll have them adjust it again but next year I'll stick an X-eng disc brake on it instead of the heavy drum lump (I can't believe how much metal gets spun up!) One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 982 ![]() ![]() |
Mine did that, turned out to be the UJ on the rear propshaft. Should that go in only 2 1/2 years of use?
Merlin. |
TRR Motorsport Member Since: 07 Oct 2010 Location: Leicestershire Posts: 115 ![]() ![]() ![]() |
Yeah, mines done that since the day it drove off the forecourt. Sounds like back lash on front diff to me but will take it in to a dealer when i can find local dealer with a decent service department (if there is such a thing). "If it ain't sideways, you just ain't tryin'! |
Ribblesdale in Settle and Kendale in Kendal,both top Defender dealers,pity they are so far away for some of us 2.4 90 XS 1968 1/32 scale Britains 109 Pick up. |
