![]() | Home > Puma (Tdci) > Engin knock |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5986 ![]() ![]() |
The VCV that's on the fuel pump can fail causing this.
Andy |
Mitche59 Member Since: 26 Oct 2015 Location: Yorkshire Posts: 2 ![]() ![]() ![]() |
Thanks for replying Andy I've edited question as when l read it back it wasn't making sense it only knocks when engine is warm when you start it & Rev the engine then is only noisy for a few seconds do you still think it's the vcv
The VCV is a common cause of engine knocking, and can cause different symptoms at different times, and would be the first thing I would swap. When it fails it will cause knock but log no problem, and not bring any warning lights on. It's particularly expensive and is easy to change, BUT needs programming to the engine.
Andy |
