Home > Technical > Dim Dip mods and MOT
chopcat
Wales 2000 Defender 90 Td5 CSW Java Black
Mrs CC needed some better lights on the 90 (Td5) so I have installed some nice ones with a relay harness. Trouble is hers has dim-dip so now the dip beams come on with the sidelights with the engine running. With the engine off sidelights only.
Now this makes total sense for driving (don't volvos do it anyway) but does it make sense to Mr MOT?
and
If I need to change it..and I have looked for the dim-dip resistor under the wing and behind the dash with no luck, I have heard that you can link a couple of pins on one of the relay blocks in the fuse board. Is that true and can someone pint me to where I might find out about what to do.
Of course if it's ok as is for the MOT then we shall leave well alone.
CC
Post #466636 26th Oct 2015 11:49am
jimbob7
OK for mot,big debate as to whether shoving low volts thru the bulb is good for longevity,I disconnected my dim dip after it mysteriously started working??On a td5 you can find the connector under the f/o/s wing,about level with the brake master cylinder. Pov.spec,ftw. 2006, 110,TD5.
Post #466638 26th Oct 2015 11:56am
chopcat
with the relay harness they are not dimmed any more so on full - dipped beam with the sidelights. as the relay sees the low volts and switches them on.
so no issue with the bulbs.
Post #466639 26th Oct 2015 11:57am
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
Mine does the same, I'd like to know how to get the dim-dip back too, I've fitted the upgraded harness but I noticed the main beam only works on the second click, otherwise you have to use flash (if that makes sense?)
I thought it was done by linking the pink plug with a wire?
Post #466643 26th Oct 2015 12:05pm
chopcat
it sounds like there may be a mix up on the feeds to the relays.Check the original connector is fitted properly to the new harness. Mine didnt work at all until i unplugged it and put it back in again.
CC
Post #466715 26th Oct 2015 5:06pm
grafty99
Disconnecting the dim dip resistor will solve all problems, the main beam forwards will only work on the second click because you wouldn't drive at night on dim dip. The resistor is there if you have dim dip, just pull the connector off and it'll disable it. Under the drivers side wing by the black vent on the wind top Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #466726 26th Oct 2015 5:30pm
chopcat
thanks for the advice (belatedly) it worked a treat. I was lookin for a big resistor but it turns out it is just a connector that lloks as if it just connects to the inside of the wing.
Anyway cheers for the help chaps
CC
Post #473110 16th Nov 2015 5:56pm
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
RE: MOT, I've got the wiring harness/relays mod on mine with Dim Dip, and it passed its MOT fine last month. I'll be taking the resistor out soon.
cheers
simon
Post #473170 16th Nov 2015 7:46pm
MuddyChris300tdi
United Kingdom 1995 Defender 130 300 Tdi HCPU Alpine White
Yesterday I got rid of my dim dip on my (300tdi) as my dipped stop working and it was the dreaded pink box. I pulled it out and made a short piece of cable and two spades as a jumper which go into poles 2 and 8 job done. On the 300tdi it's behind the gauges.
Post #473373 17th Nov 2015 7:55am
dancerdave
United Kingdom 2000 Defender 90 Td5 Exclusive HT Santorini Black
thanks guys, I've been searching for that for ages Bow down
Post #473449 17th Nov 2015 12:48pm
