![]() | Home > Maintenance & Modifications > LED bulbs in spots |
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 200 ![]() |
TBH, I've always lumped spot and pencil together as the same thing, being 10 degrees max, but preferably 5-ish. 20 for driving or 30 for a wider version, 40 to 50 for a normal main beam, and 60+ for flood, fog 90+ and flat. Of course, the distribution of light within the beam is just as important, so the basic angle is just rough descriptor. Having crewed for a rally team sponsored by PIAA many moons ago, I've always had the basis on their 5/20/95 for spot/drive/fog lamps (which is probably why I'm so picky about aux lighting). ![]()
You take a similar, more objective, view to me on such matters. ![]() ![]() Discovery 3 TDV6 Auto HSE Zambezi Silver ![]() |
Very valid points from Brendan and L4W about type of lamps fitted. I purchased my Light Force 240XGTs as I used to travel from RAF Lyneham to Bournemouth twice a week late at night or in the very early hours of the morning. The light beam and spread across Salisbury Plain was ideal for my purposes at that time and wildlife could be spotted a great distance away from eye reflection, especially the blue from deer. I no longer do that commute, Defender usage has dropped and now my driving is less rural and more urban. The scenario explained by Brendan above is now the situation I can quite often find myself in. It has improved since changing the lenses from spot to combination. Spot lenses. ![]() Click image to enlarge Combination with the opaque centres. ![]() Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
I've been noticing that the full beam lights on my Hyundai seem brighter than the Defender lights (Crystals + Nightbreakers) because on the Defender full beam is just that, whereas the Hyundai keeps the dipped beam on too. So the Hyundai looks brighter, but I can actually see further and more clearly with the Defender. |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584 ![]() ![]() |
Some good interesting points raised. I must admit I never really understood candle power/candela and prefer lumens/ lux.
Will readily admit that most light manufacturers do not help people to make a informed judgement (will resist the pun that they try to keep their potential customers in the dark etc ![]() Why do people refer to lights by the term watts? That has nothing to do with light output and watts is a unit of electrical power! Lumens is the correct unit for total light output from a device whereas lux is light'density' and 1 lux is 1 lumen per square metre. What does 1lux mean in practical terms? It is basically the minimum light you would need to read a newspaper. Why do most manufacturers insist on talking about raw lumens which is a theoretical calculation assuming everything is working perfectly? Is it be cause that value will be much higher then an actual measured lumen output figure? Many manufacturers will produce an isolux chart which shows contours of equal light intensity. Why do they take it out to 0.25 lux? Just to show how far the light can travel and still be detected by a light meter? Now if they can produce a isolux chart why not a measured total light output? Now some lights will project light over a 0.5 mile distance. Is that sort of distance needed? Stopping distance at 60 mph is about 240 feet or 77 metres. Let's give an allowance for slow reactions/ poor brakes or road surface and allow 325 feet or 100 metres. Throw in a 100% safety margin and for most people a good light output over 100-200 metres will be more then adequate. In my mind light manufacturers could present their data in a much clear format. LfW, I am not sure I understand/agree with your comment that LED are inferior in respect of colour spectrum and temperature. Inferior in comparison to what? The yellow light output from old guttering Land Rover candles? I would agree that some of the poorer quality cheaper LED are very blue prone. Light patterns are very important, along with any dark patches in the light beams. Most headlights have the broadest part of the beam some distance in front of the vehicle. Before now I have set up additional driving lights at a slight angle so that have a good wide spread of light very close to the vehicle. Brendan |
I guess such common use of Watts hails back to the days when everything was incandescent, and of similar efficiency. People love to say "I have 20,000 lumens" etc., but it's entirely meaningless without a location, and intensity too. The sun produces 6,840,000,000,000,000,000,000,000,001 lumens (think that's the right figure) - is anyone any the wiser? ![]()
They're inferior by comparison with halogen. White LEDs, and HID beams, produce their light output in a very "spikey" manner - that is to say, if you visualise the colour spectrum on a graph, LEDs/HID will have only steep spikes at certain wavelengths, and emit very little light at others. The end result is still white, but you are missing colours inbetween. Halogen, on the other hand, produces a smooth output, with near 100% of colour emitted evenly, though trailing of a little at the blue end of the spectrum. LEDs are worst in this regard, with HID in-between, but this is where halogen comes into it's own. ![]() What this means to the driver, is that while an LED/HID beam is nice and bright, things don't "pop out" as clearly. ![]() The other aspect is colour temperature - to get the most light out of an HID beam, it needs to be at 4300k, for LEDs the most light is produced at 6000k. The disadvantage of these temperatures vs the 3XXXk of halogen, is down to the way our eyes process light. We have three kinds of vision (kind of - it's more of a scale really) - photopic (used in bright light conditions), mesopic (used in meduim light conditions) and scotopic (used in only the darkest of situations). These "modes" are as a result of the rods and cones we use to detect light in our eyes. ![]() ![]() Rods are crude, with very little ability to distinguish colours, but they are able to process low levels of light well at the blue end of the spectrum. Cones recognise colours in great detail and we use them to see a wider spectrum, including longer wavelengths of red light, but they are poor in low light conditions. As a result of this, a higher colour temperature beam from LEDs/HID causes our eyes to adjust towards mesopic vision more readily due to the lack of red/orange/yellow light, and in doing so reducing our ability to recognise objects by colour gradients, and causing increased fatigue. This is the same reason that humans show a better ability to recognise a distinct spectrum within red-yellow, but find it harder to separate different tones of blue, and why the emergency services use blue lights. ![]() The other factor, is that blue light refracts more on our retinas, than red or yellow, so higher temperature light generally results in more glare. It's for these reasons, than the French with their selective yellow headlights have always had better vision on poor weather conditions, and why yellow fog lights are of benefit. ![]() The upshot is that halogen produces the best light for use by the human eye. It has low luminous efficacy (not a typo BTW), and takes more space, but given unlimited power, and space, it is the best light source. LEDs and HID come into their own when other practical reasons require it. ![]() HTH Visiting from DISCO3.CO.UK Discovery 3 TDV6 Auto HSE Zambezi Silver ![]() |
