Home > Maintenance & Modifications > BZP or Stainless steel bolts
JOW240725
I am hopeless I'm afraid... just looking to bolt on some bumperettes and wondering if i should use BZP or stainless bolts? Thank you.
Post #466090 24th Oct 2015 11:44am
Screbble
My two penneth in an attempt to help.... Very Happy
The attraction to stainless steel is the corrosion resistance I guess, but possibly at the expense of tensile strength and at the risk of reacting more quickly with any aluminium etc.
So there are benefits and disadvantages - and this excellent forum has lots and lots of info on the subject. And I mean lots - just search.
BZP or any plated steel fasteners are closer to 'standard' and will serve you well without causing you too much trouble. There's an increasing trend to move away from stainless for the reasons stated and more. Again this forum will prove invaluable in that regard.
It's personal choice - except if it's a situation where tensile strength is important (and stainless will most likely be a no no)
BUT.....
It is important that you use a paste/grease of some sort (ceramic is good) to keep dissimilar metals happy - granted that may not be the case for your project but worth bearing in mind for the future.
All of the above is only my opinion of course! Thumbs Up
PS I like stainless in the right application - personal choice Neutral
Post #466095 24th Oct 2015 12:10pm
leeds
Re: BZP or Stainless steel bolts
I presume by bumperettes you are referring to rear bumperettes or rear corner protectors?
Stainless steel will be fine. You are hardly likely to be putting massive tensile/shear or shock loads through rear bumperettes.
There are many grades of mild steel bolts as there are stainless bolts.
The most common mild steel bolts are referred to as 8.8 and the most common stainless bolts are normally referred to as A2and less common is A4
The 8.8 mild steel bolt typically has a minimum strength of 800 MPa and yield strength of 640 Mpa
A2 stainless bolts typically have a strength of 700 MPa and yield strength of 450 MPa.
With stainless nuts and bolts you can get galling or cold welding this can be avoided by using an anti seize paste.
Galvanitic corrosion will occur between dissimilar metals and this includes mild steel to aluminium as well as stainless steel to aluminium which has a bigger effect. To prevent this you need a good barrier between the dissimilar metals such as a good paint finish or powder coating, a plastic washer or anti corrosion paste.
Nakatanenga supply suitable paste with all their stainless bolt kits..
So after a long possibly tedious explanation stainless bolts will be fine to attach rear bumperettes with the use of a paste/insulator.
For high strength use I would go for 10.9 or 12.9 bolts and forget the 8.8 bolts
Brendan
Post #466120 24th Oct 2015 2:31pm
Cupboard
Another option for slightly more corrosion resistance than BZP is galvanised bolts.
Thicker layer of zinc and not shiny.
Post #466136 24th Oct 2015 3:39pm
mikeh501
Goto Westfield fasteners. Get some a2-70 bolts, nylocs and washers. Your good to go.
You won't need high strength for that apllication.
Post #466146 24th Oct 2015 4:27pm
Silver Back
United Kingdom 1998 Defender 110 300 Tdi HT Coniston Green
+1 for Westfield. I've brought quite a lot of stuff off them in the past and very pleased with their service and pricing.
They also sell a higher tensile strength stainless fastener if required for other applications.
Post #466241 24th Oct 2015 8:51pm
Mike_B
United Kingdom 2006 Defender 110 Td5 USW Java Black
I use a2stainless.co.uk
Fast service, good prices. 10% discount too.
Post #466259 24th Oct 2015 10:01pm
