Home > Td5 > oil change
Tommo
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
oil change
I change all filters every 12k but is it ok just to change oil at 6k?
Post #465624 22nd Oct 2015 9:00pm
excossack
I change mine every 6months, which sometimes is more than 6k or sometime a bit less.
Fuel/Oil/Rotor filter/Air filter/Engine oil - all changed. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #465630 22nd Oct 2015 9:10pm
Tommo
But is it ok just to change the oil Confused
Post #465900 23rd Oct 2015 5:41pm
excossack
I don't see why not.
Maybe other people with other views.? 1999 Defender TD5 110
Regards
John M0VAZ
Post #466039 24th Oct 2015 8:19am
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
Completely fine just to change oil then filter at 12,000 the main full flow filter service is every 12,000 and the rotor is every 36,000. For the price I just do everything at 6,000.
Regards
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #466048 24th Oct 2015 8:58am
Screbble
For the modest cost and minimal time involved, I'd also change the oil filter (genuine) aswell at 6k Thumbs Up well worth it for the peace of mind.
Post #466061 24th Oct 2015 10:03am
Tommo
I think you are right for the extra �10 for a genuine filter...might as well change it Thumbs Up
Post #466240 24th Oct 2015 8:50pm
Podrob
When I recently changed the cartridge filter I noticed that the replacement was much easier to fit than the original was to remove. I found the replacement was 99mm long compared to 106 mm of the original. Both are genuine landrover part no LPX100590 so they are now making the filter slightly shorter. Makes it much easier to get on and off.
Post #466867 26th Oct 2015 11:11pm
Tommo
That's interesting about filter length, however last time I changed it , it was actually ok to get off. The most difficult thing for me was replacing air filter as it took ages to align it in the box Shocked
Post #467072 27th Oct 2015 7:21pm
Podrob
I got the shorter one over a year ago so they have been like that a while. Another reason to use genuine filters as pattern ones may be based on the longer version which are very difficult to fit and remove. Older stock genuine filters are also likely to be the longer ones.
Post #467102 27th Oct 2015 9:22pm
jimbob7
Regards
Will
The other way round,rotor filter at 12k,main filter at 36k.
 Pov.spec,ftw. 2006, 110,TD5.
Post #467234 28th Oct 2015 11:58am
jimbob7
Yeah,ive noticed that,think the black one is the slightly shorter one (same part no.),dunno why,doubt landrover do either,lol! Pov.spec,ftw. 2006, 110,TD5.
Post #467237 28th Oct 2015 12:04pm
grumpy old git
AFAIK the shorter one was designed for the defender, but it gets used on the D2's as they go in a bit easier.
Post #467342 28th Oct 2015 6:30pm
Podrob
That's right the shorter one was black and the original white but both with the same part number. I also had a Coopers one described as OE which looks identical to the Black Genuine LR one.
Post #467403 28th Oct 2015 9:51pm
Screbble
Thanks for that info Podrob, I'll bear that in mind at the next service as the smaller filter will make the job a bit easier. Mine is 106mm.
Cheers,
Will.
Post #467756 30th Oct 2015 9:35am
