Home > Puma (Tdci) > Transmission clatter
Bosun
2008 Defender 90 Puma 2.4 XS CSW Tonga Green
When driving off-road in 2nd low, downhill, low idle with engine braking, there is a very loud clattering from the transmission. Anyone got any ideas what's wrong.
Thanks.
Post #46491 27th Nov 2010 4:27pm
AndrewS
Clutch I expect. When you turn the engine off can you hear a couple of metallic "clunks" from the underside of the car just as the engine stops rotating. 130's have feeling's as well you know Smile
Post #46501 27th Nov 2010 7:50pm
toshers
Scotland 2011 Defender 110 Puma 2.4 USW Orkney Grey
Is this noise the clutch? Mine has started doing this recently. I've also noticed a similar noise at idle!
Post #46520 28th Nov 2010 6:39am
AndrewS
Yep its the little coil springs in the pressure plate. They slacken off and rattle. Warranty fix Thumbs Up 130's have feeling's as well you know Smile
Post #46530 28th Nov 2010 12:43pm
MK
The other day at the stealer I was able to had a look to the lastest version (2?) and 1 of 4 sets of springs was quite loose. Puma 110" SW
Post #46536 28th Nov 2010 4:27pm
Bosun
Thanks all. Not very encouraging though, I'm on my second clutch plate at only 20,000 miles.
Post #46538 28th Nov 2010 4:41pm
AndrewS
My last one lasted 5k 130's have feeling's as well you know Smile
Post #46557 28th Nov 2010 7:36pm
MK
Ford Puma 110" SW
Post #46559 28th Nov 2010 7:58pm
Toplink
Had all these noises on my 90 31000mls clutch done on warranty.My 200tdi dico did 120000 mls on first clutch,only changed as g/box was taken out.Good old landrover one step forward two backwards. Still best 90 i have driven.
Post #47508 5th Dec 2010 9:52pm
Bosun
Thanks. Just waiting to see if the dealer comes to the same conclusion. I can do but wish!
Post #47554 6th Dec 2010 11:00am
