Home > Puma (Tdci) > Rear Third Brake Light LED ?
Page 1 of 4 1234>
SkyFallSilver
Kuwait
Hello,
Is there any LED for the rear window lights to replace the OEM Brake light ? 2016 Defender 90 Adventure Edition
Post #464994 20th Oct 2015 6:00pm
K9F
Vehicle Glazing Specialists (formerly Landyglass) supplies EU approved LED rear glass LED lights. Maybe give him a call and see if he can provide you one or give details where you can get one from?
http://www.vehicleglazingspecialists.com/-90-products.html If you go through life with your head in the sand....all people will see is an ar5e!!
Post #465031 20th Oct 2015 7:24pm
Sadi
Namibia 2016 Defender 110 Puma 2.2 Heritage Edition SW Grasmere Green
This one from Hella also nice:
http://www.danielsternlighting.com/products/products.html
http://www.thesamba.com/vw/forum/viewtopic...p;start=20
Saw the other day on a Land Cruiser a rear facing light bar mounted on the roof with LED main rear red lights, brake lights and indicators. With remaining space in middle for a LED work light bar.
Did not get close enough to snap or see manufacturer name.
All with clear lenses - but lighting up in the appropriate color - red/orange.
Looked rather nice.
Post #465185 21st Oct 2015 9:49am
Martin
Site Admin
I think SFS is after something to put in the existing unit, rather than replacing it with another non-factory unit?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #465186 21st Oct 2015 10:01am
SkyFallSilver
Kuwait
exactly I want to replace OEM one 2016 Defender 90 Adventure Edition
Post #465188 21st Oct 2015 10:04am
nakatanenga
Germany
We have a replacemt unit in r&d and we will have the pre production samples this year. Together with an OE design red/white switchable LED interior light WANTED:
SII or SIII in max 1.5k
Post #465209 21st Oct 2015 11:32am
SkyFallSilver
Kuwait
Great then I will wait for your products 2016 Defender 90 Adventure Edition
Post #465264 21st Oct 2015 2:48pm
gilarion
I do not know if this is any help to you but I fitted one of these to my high level brake light very bright much better than the OEM bulb.
http://www.ebay.co.uk/itm/BA15S-12V-24V-PU...61rTZVxXrg
 For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #465286 21st Oct 2015 4:15pm
dgardel
Italy
Waiting news......... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #465686 22nd Oct 2015 11:45pm
Only 10 ish weeks left Pete for this Year Shocked
Post #465697 23rd Oct 2015 6:58am
ericvv
As seen on a Malaysia 110 double cab limited edition. This LED 3rd brake light would be an interesting one to install on a SW too, for instance on the upper door frame itself, or on the panel above, and same time replace the rear window by a version without the standard 3rd brake light with its incandescent bulb/holder.
Anybody have an idea which brand this LED brake light is?
Eric
 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #475049 22nd Nov 2015 7:36am
I like that but it's a bit extreme having to take the canopy off to make functional.
Post #475108 22nd Nov 2015 12:37pm
SkyFallSilver
Kuwait
I would prefer to have OEM style 2016 Defender 90 Adventure Edition
Post #475152 22nd Nov 2015 3:55pm
SkyFallSilver
Kuwait
Any updates ? 2016 Defender 90 Adventure Edition
Post #484531 22nd Dec 2015 5:59pm
Merlin
I fitted the LED bulb as above, quick fix and effective. Had to swop the two wires over, as LR had the polarity different. All simple stuff.
I also fitted a flash unit, which gives 5 flashes before coming on hard. There is an override in case of MOT problems. With the LED it is very distinctive and (hopefully) safer.
Merlin
Post #484785 23rd Dec 2015 12:38pm
Page 1 of 4 1234>
