Home > Technical > Diff guard and Panhard rod...
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
After witnessing the effect of a close encounter between a rock and a front diff on another vehicle, I decided to fit a diff guard to mine.
So I ordered this:
I initially thought it would be an easy job to fit... How wrong I was, I just cannot get the ring passed the panhard rod, it's just impossible! Even when matching the small recess in the ring with the bulge on the diff Evil or Very Mad
So I thought I would release the panhard rod at one end, but then on one side the bolt cannot be removed because of the axle, and on the other side, it's the nut which is unreachable, I can't get a spanner to fit in the recess.
Any hint? I feel daft now... Big Cry
Post #464863 20th Oct 2015 8:23am
Jonno1968
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Orkney Grey
The front one is normally easy....you wait until you get to the rear one....mine is still in the garage un fitted so you have my sympathy!
Post #464865 20th Oct 2015 8:35am
How about jacking up the nearisde end of the axle until the offside end is just clear of the ground? That (I would have thought) would skew the axle to get the panhard rod clear of the diff.
Even just jacking the vehicle up under the bumper until the axle is hanging free should do it. This picture (provided by google image search and stolen from the internet) should give you the idea:-
Post #464870 20th Oct 2015 8:45am
Roy5695
As blackwolf said, or if you take the centre grill off and push the radiator up at one end theres just enough room to get a spanner in and hold the nut to undo the bolt!
Had to figure this out myself when fiiting my steering guard last week.
Post #464871 20th Oct 2015 8:48am
o4dn
Yeah I tried jacking up the car, but ... mine is LHD meaning the panhard rod is attached on the other side, i.e. it's linked to the axle on the same side as the diff...
Post #464873 20th Oct 2015 8:55am
Aha, LHD, I hadn't thought of that! You'll probably have to disconnect the Panhard rod then.
Memo to self - pay attention to the little flag icons!
Post #464890 20th Oct 2015 9:57am
o4dn
Yeap, removing the panhard rod is what I've been trying to do, but I can't even manage to do that... Big Cry
Post #464892 20th Oct 2015 10:19am
What's the problem removing the bolt from the axle end of the Panhard rod? It looks from the photo below (again stolen from the web) as though it should be straightforward.
Alternatively can you fit the guard by removing the clamp bolts, turning it so that the opening is in the 9-oclock position as viewed in the photo above, inserting it between the Panhard rod and axle, then sliding the gap where the clamp bolts fit along the rod from right to left until the guard is on the diff, then rotating it to the position shown. (Hopefully you follow this, it would be easier to demonstrate than describe).
Post #464918 20th Oct 2015 12:55pm
o4dn
The problem disconnecting the panhard rod from the axle is getting access to the bolt behind, it's placed in a recess in the axle itself where the spanner won't fit.
I already tried the rotating method, as I noticed there is a notch in the diff guard, but that's still too tight to fit in between the panhard rod and the diff...
I'll give it another try tonight, with the help of a jack to move the rod a bit further away from the axle maybe...
Post #464948 20th Oct 2015 2:26pm
tatra805
Slovakia 2008 Defender 110 Puma 2.4 CSW Bonatti Grey
With diff guard in front of you (opening on top, 2 bolts removed) holding it next to diff between panhard rod and axle
Turn guard 90° anticlockwise
Slide the top opening of the guard "on top of" the panhard rod (opening should open up enough with a bit of pressure) so it clamps the rod
now slide guard to the left (in front of diff) while still having the top opening clamping the rod (while sliding)
When far enough, push top opening of guard towards axle so it releases from the rod
Turn guard 90° clockwise, fit on diff and put back guard bolts.
No idea if this makes sense but this is how i do it without removing the rod
Thumbs Up
edit: note: do not bend open the 2 arms of the guard too much, you'll struggle to bent it back once the cover is in place and you need to put the bolts back
Post #464979 20th Oct 2015 4:54pm
^^^ I think that's what I said! Thumbs Up
Post #465016 20th Oct 2015 6:45pm
o4dn
Fitted! Thumbs Up
Many thanks blackwolf and tatra805, that was the way to go (with a bit of persuasion...)
Post #465035 20th Oct 2015 7:32pm
