![]() | Home > Maintenance & Modifications > Can you ID the bolt?! |
Northernremedy Member Since: 18 Aug 2014 Location: Yorkshire Posts: 122 ![]() ![]() ![]() |
http://www.a2stainless.co.uk/Land-Rover-De...ARZ9M.aspx
Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
You're the man thanks!
RoddyK05 Member Since: 08 Apr 2015 Location: Inverclyde Posts: 633 ![]() ![]() ![]() |
Moisture in the footwell probably a combination of things - have you noticed how much ends up in there from the roof gutter every time you open the door when it's raining? No doubt someone will prove me wrong, but I'd say damp foot wells were just a sideline of owning a Defender. Glad I've just got mats and not carpets.
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2324 ![]() ![]() ![]() |
Definitely something you should get used to ![]() I agree on the roof gutter problems - and not always/just when the door is open! ![]() Also have a closer look at the faux windscreen hinges (gaskets) and the horizontal seal. ![]() |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20998 ![]() ![]() |
If you replace one of those with SS make sure you use corrosion block / corrosion prevention paste
Cheers gang! Think some moisture may be coming down through the door. The door bottoms aren't looking in their first flush of youth.
Nipped the bolts up and they took so wil replace at some point! |
