![]() | Home > Maintenance & Modifications > Warn Winch battery cables.. Long enough? |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2947 ![]() ![]() |
Anyone know if the 72" battery cables are long enough to get to the battery?? Can't imagine they would be...do warn do an extension kit or what do you guys normally use?
Thanks Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
You are right, got confused with another thread. Andy
mse Member Since: 06 Apr 2008 Location: UK Posts: 5117 ![]() ![]() ![]() |
Incidentally Warn do do an extension kit they fitted it to my winch and when we ordered teh genuine LR bumper it came with the extension cables too Mike
It would appear that the 72" cables are not long enough. For the positive to reach the battery terminal you actually need approx 10 feet. I will either check if I can get an extension kit from flatdog or will have some new cables made up. Andy
The exact length cables are available, i may even have a set.
Were did you get your warn from arbil4x4 are the only UK importer - speak to them they will sort you out a set. For me they sorted and fitted at cost of the cable Mike |
Got it from flat dog, would be much better to have the correct lengths as you says it's no hassle of extension joints, have the old ones bolted off, in fact found a stray nut lying inside the controller, poor QC warn....
![]() 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
