Home > Technical > Disklock Size
mse
Disklock Size
What size is needed for the puma...some say medium, some large, I think their site says large.
Obviously you want the tightest Mike
Post #464266 18th Oct 2015 11:06am
alby
United Kingdom 2015 Defender 90 Puma 2.2 SW Santorini Black
I use large on my defender.
You actually want the disc lock to be loose (rotates freely) on the steering wheel so the steering wheel cannot be turned by turning the disc lock.
There is a modification that can be done to prevent the disc lock from being pried off of the steering wheel too, well worth searching for it on the forum.
Post #464275 18th Oct 2015 11:48am
sat13
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Santorini Black
As above, large so it is slack on the wheel. That is for a standard size Puma wheel.
Post #464277 18th Oct 2015 12:02pm
strang
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Galway Green
I have a Medium on my Puma (standard wheel fitted) and it is still a loose fit. Euro-Leafing to infinity and beyond.....
Post #464630 19th Oct 2015 1:08pm
miket
I also have a medium on my Puma (standard steering wheel) and it's a loose fit.
Post #464640 19th Oct 2015 1:21pm
jimbob7
Really, I had to buy a large coz my old medium Disclok wouldn't even come close to fitting.
This is the wheel I had/ have;
To this...
Only large would fit??On the "tightest" fitting as there are 3, there is still some slack (as there should be),this stops you using the disclok as a "steering wheel". Pov.spec,ftw. 2006, 110,TD5.
Post #464647 19th Oct 2015 1:38pm
miket
Yep, definitely a medium - I've just checked - and it fitted both my old Td5 and current Puma just fine (it was loose on both).
Mike
Post #464712 19th Oct 2015 6:04pm
strang
I have the lower style wheel (with dummy air bag) and the medium is a perfect fit. I doubt you could turn the wheel anyway, as the locking bar part of the disk lok catches on the windscreen. Euro-Leafing to infinity and beyond.....
Post #464735 19th Oct 2015 7:22pm
gilarion
I was under the impression that the Disklock medium and large lock was the same size Confused the only difference being the the medium size has extra padding fitted on the inside of the lock… For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #464917 20th Oct 2015 12:48pm
strang
Dunno about that, but I can confirm that there is some kind of material insert/padding inside my disklock. Euro-Leafing to infinity and beyond.....
Post #464919 20th Oct 2015 12:57pm
gilarion
If you talk to Disklok, they will say medium and large are same size but there is more padding in medium. Dislock make two sizes small and Large the medium is the same as the large but with extra thick padding
The large size internal measurement is 41.5 – 44 CM
The medium internal size with the padding is 39 – 41.CM
However if you measure the outside diameter of both they are the same For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #464957 20th Oct 2015 3:13pm
strang
I had a better look at my 'medium' Disklock today, and there are indeed several thick 'pads' located all around the inside of it, so it could well be the same size as a 'large' one' only made to fit a bit more snuggly I guess. Euro-Leafing to infinity and beyond.....
Post #465229 21st Oct 2015 12:40pm
tonyhedge
2014 Defender 90 Puma 2.2 SW Montalcino Red
Just fitted a "large" to my Puma, my steering wheel is as per the lower of Jimbob7's photos above, ie the one with the fake airbag bump.
I ordered the inner steering wheel cover too. With that, certainly the "large" fits well, and on the tightest notch is a good fit with enough clearance for it to turn freely. Have no doubt the "medium" would fit too on the widest notch, so if you have, or have a chance of, a medium, go for it.
And in its bag, it stows neatly between the back of the seat and the "bulkhead removal rail" on a 90SW. Good idea to add a bungy cord to keep it there in case you end up upside down.
Ordered mine directly from Disklok, excellent service, both company and product highly recommended.
[Edited to correct appalling punctuation!] That's not a dent, it's a rivet. That's not a dent, it's a rivet. That's not ... oh! That is a dent!
2014 90 XS SW
1997 Discovery 300TdiS (retired to stud)
1966 Series IIA 88" (now my son's)
2001 Astra - I need something to go and buy the parts when the others are off the road!
Post #465621 22nd Oct 2015 8:53pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
Measure your wheel and use their Web site.
I was going to get a large till I measured it. It turns out my steering wheel is aftermarket but with a landy badge. Hence a small fits mine no bother and is still big enough to rotate. A large would have been too big. 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #465625 22nd Oct 2015 9:00pm
mse
Thanks everyone
Just ordering so thought i would measure - it looks like the wheel is 41.5 which is why the medium and large both must fit!
We have the later wheel XS style wheel (with the buldge) so will probably go medium Mike
Post #466115 24th Oct 2015 1:31pm
