|  | Home > Wheels & Tyres > Mix and match? |
| YOLO110 Member Since: 14 Feb 2015 Location: Perth Oz and Stansted UK Posts: 1648    | NO worries mate, as long as they are on the same axle all will be well.
 I would fit the new tyres to the front axle however... Those new BFG AT's look GREAT!  I wish I had seen these before fitting my Continental A/T!!  YOLO... You Only Live Once... | ||
|  18th Oct 2015 4:49pm |
| MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 692      | Mixing 235/85/R16 on one axle and 265/75/R16 on the second axle? This is not good idea, and I think, it is not road legal, at least here in Czech republic. "Drobek" = The Small One - Discovery 2, "BlufĂnek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo   | ||
|  19th Oct 2015 5:09pm |
| nidge n Member Since: 04 Feb 2012 Location: Cheshire Posts: 720    | I can't see that being legal in the UK as one axel will not match your spare. | ||
|  20th Oct 2015 6:06am |
| theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862  | Perfectly legal BMWs are sold standard with fast tyres on the rear and skin on the front.
 As mentioned the size needs to match on the same axle. Buy two tyres are a time. Nothing wrong with that | ||
|  20th Oct 2015 6:36am |
| L90Andy Member Since: 29 May 2014 Location: Stratford-Upon-Avon Posts: 728      | Shouldn't be a problem as the two sizes have basically the same rolling radius. You may just lose out on steering lock with the wider tyres on the front.
 It generally frowned upon to have tyres of different rolling radii, but ok for widths as per orangebandit says, you can by cars with differential fit tyres, albeit wider on the back. | ||
|  20th Oct 2015 6:58am |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18058      | The difference in nominal diameters between a 235/85 and a 265/75 is around .08 of an inch, so less than 1/10th (the 265 is in fact the smaller).
 The difference between a worn tyre and a new tyre is far more than this. It will be unconventional but won't cause any problems. | ||
|  20th Oct 2015 8:23am |
 Space-saver spares don't match anything and are legal. | ||
|  20th Oct 2015 8:24am |
| Bows Member Since: 07 May 2012 Location: Wales Posts: 525      | Defender is full time 4x4, not a good idea to fit different size tyres, it can cause premature wear in the drivetrain. 2006 TD5110 station wagon
 1995 300Tdi 90 truck cab 1989 90 hard top with 200 tdi 1983 110 hard top 1983 110 Hi cap 1954 107 pick up | ||
|  20th Oct 2015 9:35am |
| Triggerfinger Member Since: 18 Aug 2015 Location: landyrotty Posts: 129    |
 My m3 has 245/35/19 on the front & 315/25/19 on the rear the difference being its rear wheel drive!!! As long as the rolling radius is near the same it would be fine  | ||
|  20th Oct 2015 9:38am |
 EXACTLY!   My Lotus came standard with 16 inch fronts and 17 inch rears... different width and aspect ratios but the rolling radius was the same... give or take tread wear. Anyway, if you have any doubts, just call your local MOT place. YOLO... You Only Live Once... | ||
|  20th Oct 2015 10:29am |
| Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1697    | Hmmm ask your insurance or better still tell them you modified the vehicle  to save money
 Guess the repsonse. It's different if your car was designed and type approved with different size wheels and tyres.lots of bmw inc their 4@4s have larger rear wheels and tyres. Unless you know better I think most of the defenders,disco and range rovers of recent years have come with the same size all round. I suspect they have their reasons for doing this.... | ||
|  20th Oct 2015 4:26pm |
| Bows Member Since: 07 May 2012 Location: Wales Posts: 525      | Guys, fitting different size tyres will cause "wind up" in the centre diff and in turn, cause premature failure. Comparing it to a M3 and a Lotus is totally missing the point. Do not fit different size tyres. 2006 TD5110 station wagon
|  20th Oct 2015 5:02pm |
| Triggerfinger Member Since: 18 Aug 2015 Location: landyrotty Posts: 129    | Why would it cause wind up if the rolling radius is very near the same????  more like having worn
 tyres on one axle & new on the other, even then it wouldn't cause wind up!! | ||
|  20th Oct 2015 6:12pm |
| Bows Member Since: 07 May 2012 Location: Wales Posts: 525      |   Ok, crack on, there are plenty of transfer boxes on eBay!!  2006 TD5110 station wagon 1995 300Tdi 90 truck cab 1989 90 hard top with 200 tdi 1983 110 hard top 1983 110 Hi cap 1954 107 pick up | ||
|  20th Oct 2015 6:42pm |
| Posting Rules
