Home > Maintenance & Modifications > Fitting New Wheels
rob369
United Kingdom 2013 Defender 90 Puma 2.2 HT Aintree Green
Fitting New Wheels
Hi all, I am going to fit a set of new take off LR boost alloys to my newly acquired 90 hardtop . Can anyone enlighten me as to whether I need to apply copper grease to wheel contact face and advise wheel nut torque wrench settings. Many thanks Rob
Post #464285 18th Oct 2015 12:38pm
YOLO110
Australia
Copper slip... a good idea
130 ft lbs I recall is correct. YOLO... You Only Live Once...
Post #464287 18th Oct 2015 12:53pm
rob369
g'day yolo, Thanks for the advice, good luck in the rugby. rob
Post #464292 18th Oct 2015 1:08pm
fathaggis
you will need spacers on if you want to keep the hubcap cover on the boosts Question
Post #464306 18th Oct 2015 1:43pm
apt100
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Aintree Green
There is some discussion of torques in page 12 of this thread... http://www.defender2.net/forum/topic31672-165.html
MY16 owners book has 170 Nm (125 ft.lb) for 7" alloys... https://topix.landrover.jlrext.com/topix/c...e79!!3!225
Post #464311 18th Oct 2015 2:13pm
ericvv
Very strange if topics says 170Nm for 7" alloys. I just logged on to topix and on page 114 of the user manual it reads as copied below:
9. With all wheels on the ground and the jack
removed, fully tighten the wheel nuts in the
sequence indicated above to the correct
torque of 133 Nm (98 lb.ft).
I think the 170Nm applies to 6.5" HD Wolf wheels only.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #464344 18th Oct 2015 4:00pm
apt100
From the link I posted.......
Post #464347 18th Oct 2015 4:07pm
ericvv
I can well believe you, so two possibilities as topix for my 2009 model still reads 133Nm today....
1. the recommended torque for 7" alloys has increased from the 133Nm for a 2009 model Puma to 170Nm for those that roll out of Solihull now.
2. there is a misprint in the topix for the current model years where someone accidentally used typed the 170Nm for the HD Wolfs also as the number for the alloys.
Seems a question for our dear Ryan of Land Rover Customer Relations. His collegues inside should be able to clarify which numbers are correct for each of those wheels and if there are any changes in recommended torque between 2009 and today.
Until further notice, I continue to use what is written in my topix for 5" alloys, i.e. 133Nm
Ryan, please comment. Question Question Question Question Question Question Question
Post #464351 18th Oct 2015 4:19pm
apt100
This is now going off-topic, but as you have asked Ryan to comment - there is a definite error in MY116 manual I noticed recently. The index entry for fuel tank capacity points to page 114. But it clearly isn't on page 114.
Where there is one error...maybe more?
Post #464360 18th Oct 2015 4:34pm
YOLO110
Australia
LOL! Laughing YOLO... You Only Live Once...
Post #464378 18th Oct 2015 5:28pm
SailingTom
He shouldnt do that was only early 90's and 110's not defenders, his will be fine without spacers Thumbs Up
Post #464419 18th Oct 2015 7:05pm
Retroanaconda
Actually the 'wide hub' drive members which prevent the fitting of those alloys continued into Defender production. They disappeared when the 300Tdi came in and brought the thinner hubs and drive members.
Post #464446 18th Oct 2015 8:04pm
rob369
Hi everyone, thanks very much for your input, I fitted the wheels to my 2011 defender yesterday torqueing the wheels to about 130 nm. They look great! It even seems to drive better! The only thing I was not sure about was as to whether to remove the small rubber dust cap from the centre of the hub but they seemed to fit over them ok.Cheers Rob Smile
Post #465202 21st Oct 2015 10:49am
Happyoldgit
No, the dust cap stays put! Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades.
Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone.
http://forums.lr4x4.com
Post #465207 21st Oct 2015 11:21am
rob369
Thanks Steve, that puts my mind at rest.Rob
Post #465210 21st Oct 2015 11:32am
