![]() | Home > In Car Electronics > Spot light switch wiring.... |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2947 ![]() ![]() |
I have done a search and got about 90% of the info but I have a specific question... My rack lights loom from Mobilecentre has 2 pins that go into 1 and 5 in the landrover spot switch.... So I am assuming that I can just tap into a neighbouring switch for the illumination feed?? Into slot 2. But what about the switch ground?? Do I need it?
Thanks Andy Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
Paulmc posted this helpful diagram a while ago.
![]() Click image to enlarge Hope it helps Ray My build thread http://www.defender2.net/forum/topic17615.html |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 ![]() ![]() |
From memory you'll need the ground for the illumination, I just took both off neighbours
Yeah have seen that one...its the switch ground I need to get from another switch. Anyone know which pin is ground in either the rear wiper or washer switch? Andy
Yeah think ur right.. It easy to find the illumination feed as I can read 12v with the side lights on... I guess the ground wire in a switch won't have any volts? Andy
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 509 ![]() ![]() ![]() |
The switch earths are Black wires - On pin 4 on the rear wiper switch On pin 2 on the rear washer switch The switch illumination lives are on Red/Orange wires - On pin 2 on the rear wiper switch On pin 5 on the rear washer switch . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
Perfect Paul.
Thanks Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
