Home > Wheels & Tyres > 285/75/16 on Sawtooth wheels anyone ?
Page 2 of 2 <12
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
jackp wrote:
I'm running a set on 16" sawtooths. I love them, kinda wished I had gone whites out tho. Big Cry
I disagree, definitely made the right choice with white lettering inwards Thumbs Up Looks great IMO
Post #462935 13th Oct 2015 5:09pm
jackp
United Kingdom 2009 Defender 90 Puma 2.4 PU Stornoway Grey
I disagree, definitely made the right choice with white lettering inwards Thumbs Up Looks great IMO]
Cheers mate
Post #463386 15th Oct 2015 8:30am
jeffersj
United Kingdom 1996 Defender 90 300 Tdi HT Bronze Green
wizz80
You will probably need spacers but definitely need to adjust the lock-stop. Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #463390 15th Oct 2015 8:42am
wizz80
I have spacers so think I will give them ago I don't really do any thing to axle twisting so hopefully will be ok
Post #463467 15th Oct 2015 12:31pm
TSAF
Greece 2015 Defender 110 Puma 2.2 HT Venetian Red
need4speed wrote:
285/75-16 mickey thompson on sawtooth alloys with 30mm spacers..
Are you running any lift? looks great
Post #978963 20th Jan 2023 1:30pm
TSAF
Looks great. Any issues on highway speeds? Any wobbling?
Post #978971 20th Jan 2023 2:37pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
Just a quick point that nobody seems to have made re: the larger diameter tyres v fuel consumption issue....
With the bigger tyres, your mileometer/odometer will be recording less miles than it was previously (not that they are ever particularly accurate IME) so regardless of the true mpg figures, on paper it will appear to have suddenly worsened by a few percent at least, unless you factor in a correction for the tyre size change. Some manufacturers actually publish a figure for this based on revolutions per mile for each size, which can give you a useful indication if you are not fluent in tyre'ese.
Post #978987 20th Jan 2023 4:12pm
Soulrider911
United States 1989 Defender 90 2.5 TD SW Chawton White
Hey friends, I have a set of 16” sawtooths and 30mm spacers on the way. I am thinking of trying 285/75’s but my rig is stock height… anyone you running this setup have it working on a stock height Defender? Thanks 1989 Defender 90
2022 Defender 110 SE
DIY’er | Always learning
Post #981930 9th Feb 2023 11:02pm
Linds Hanson
need4speed wrote:
Defender-Stu wrote:
I have been told 285x75x16 will mess up the gearing and could damage diffs and use more fuel?
Will raise gearing slightly. So acceleration will be dampened a little but at 70mph your revs will be reduced so in actual fact on a steady run your mileage will actually improve.. If your concerned about losing a little acceleration either get a remap or do what I did and fit a 4.6 V8...... Laughing
Damage diffs? Nonsense..
Edit: Tyres don't damage diffs, bad driving does. Some people can grenade diffs with standard tyres/power.. Laughing
RV8'S of any capacity including 5.2 or supercharged are hopeless with tall gearing they actually drive much better with 1.4 transfer gearing
Post #982000 10th Feb 2023 4:22pm
Jonothethird
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Tonga Green
Yes - I’ve got 285/75/16s on Bowlers with 30mm spacers (or maybe 25mm?) on my standard height 90 puma and no problems. If I have a load of weight in the back (3 blokes and a couple of dogs) it will occasionally touch at the back around corners but i don’t do that often! Great tyre size for the defender imo and BFG AT2S are brilliant off and on road
Post #982702 16th Feb 2023 9:42pm
Page 2 of 2 <12
