![]() | Home > In Car Electronics > Using a heated seat switch for reverse camera.... |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2946 ![]() ![]() |
I have a spare heated seat switch which I have a new head attached to from a discovery just to have a different symbol.. Anyway I want this switch to trigger the reverse camera, anyone suggest what way I need to wire the switch.??
Thanks Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6681 ![]() ![]() ![]() |
Puma heated seat switch?
If so: 1 12V in 2 illumination 12V 3 not connected 4 12V out 5 ground ![]() ![]() |
Thanks Martin,
Yes Puma switch.... What could i use for 1 and 2?? Can i just tap into the wires to a heated seat switch? Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
Yes if the current draw you are taking is small
Understand, so really I would be better to take the 12v in from the battery? Rest ok from the other switch? Andy
What is it powering? You say a reverse camera so presumably you can find out the current draw?
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1317 ![]() ![]() ![]() |
For a reverse camera, the cigarette lighter is also an option - it has a 20A fuse I believe
Yup, will look it up when it arrives tomorrow, just an Alpine rear camera that I want to be able to fire up with reverse or the switch... Andy
Heated seats are 20A too.
Dave Bellis Member Since: 21 May 2014 Location: Shrewsbury Posts: 133 ![]() ![]() ![]() |
What is the maximum current that a seat heat switch YUF500150LNF contacts can carry?
The pair of seats are fused at 20A, so I wouldn't be putting more than 5A through one of these switches.
Slight side issue, I was thinking of switching about 2 amps through one of these switches just wondered about the contact current rating?
Last time I checked, 2 is less than 5
the power consumption is rated <2.5 watts so think i should be ok...
![]() 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
