![]() | Home > Maintenance & Modifications > MSS Rear Window Guards into 09 110 CSW |
Blacktt600 Member Since: 30 Nov 2013 Location: Leeds Posts: 125 ![]() ![]() ![]() |
I had the same problem, when I phoned them asking for help they said they had just been told of the problem and they would look into it and come back to me. Obviously not a problem on the TD5's
Seems strange that they are still selling theses for the puma knowing they don't fit. I ended up chopping and carving the grill which was a pain in the backside! Think you will find that once fitted the window side trims will need cutting in the length owing to the rear guards sranding proud of the rubber glass seal. Think I have photos some where if needed. Good luck with it, you'll need it! |
Krissvdh Member Since: 18 Mar 2015 Location: Rutland Posts: 12 ![]() ![]() ![]() |
I was hoping this wasn't the case. I may remove the bracket and see if i can slip it underneath. I'm sure i've seen someone on here with a 110 CSW with these fitted.
Kris |
I managed it but it was a pig, you can't tell I had chop the grill once it's fitted.
I posted a photo of he finished install if you do a search. |
